I’m using one of those power saver power bars. It has one “control” outlet and the rest are followers. My laptop power supply is plugged into the control socket. Everything else is in the follower outlets.
When I start up my laptop my work light turns one, my fans turn on, the power to the laser machine turns on.
When I shut down my laptop, everything else turns off too.
It is very handy. Is there any problem with this setup I’m not seeing?
I don’t see any issue. There is no sequence you need to follow. You can turn on and off the lasers as needed.
