Power Scale below 10mm/sec w/Ruida?
I’m wondering if it’s possible to create a power scale with a Ruida controller when cutting at or below 10mm/sec?
I’m aware of this limitation:
But I wasn’t sure if there was some way that I could still use the power scale and have the output set the min and max power to the same values for each object.
Thank you,
Jared
Go in to the machine settings and you can set your Start Speed to any number you like. Just because it defaults to 10 mm/sec doesn’t mean you cant change it.
Ah, good point.
Thanks!
Jared
