Power Scale Help
Hello All:
So I am working with the Power Scale option and am running into an issue I think. So I am trying to create an Engraving Power/Speed Test where I have 10 Rows by 10 Columns and I have my max speed on the spectrum at 350 mm/s and the max power at 95%.
The issue I am running into is that when I run the file, 10% Power at 350 mm/s is coming out really dark.
Am I not using the Power Scale Right? My Layer Settings for example are Speed: 350 mm/s, 100% Power Max, 50% Min, and .07 LPI.
Thanks in advance for the help…
Michael K.
Read this thread it helped me alot with my issue
Also read this one.
Sorry for so many replies but I also just remembered my issue a few days ago, you have to set a minimum on your color for that speed. Whatever you minimum to get the tube to fire. I have my mine set to 9 and the max to 100%, and my power scale goes from 10% to 95%.
50% min is the reason. Power scale is a percent between min and max, so 10% in your case is 10% of the way from 50% to 95%, or about 54% power.
Okay I’ll give that a try next. That makes sense.
