Hi, I have a similiar issue like the forum post from Jan. 2020 (click), I created a material test, the layers which have “fill-mode” work as expected and use the power scale feature, the layers which use “line-mode” do not however.
min power line-mode: 0
max power line-mode: 100
the elements power scale setting is set in a range from 65 - 80 %
however when i start the machine the display says 98% power (why 98?) and the machine is 5 mA above the recommended max. for my tube.
I will link the file for you. Example picture as well.
6,5mm_Mat_Test_Wood.lbrn2 (202,1 KB)
