I’m having trouble with the Print and Cut function specifically but it might be an accuracy issue across the board. I’m running an XTool D1 and trying to use the Print and Cut function but it “randomly” is off by about 3mm in both X and/or Y axis.
In the attached picture you can see two attempts to hit the same marker. Both attempts were following the same process, i.e. at least those two markers should’ve aligned at the very least.
