I am using a AWC controller 708C LITE
When i start LB than it will find my laser and i can send a file to the laser. But when i will send a second file than i get the message that it is not possible. When i restart LB again it is working again for 1 file. What can i do about this?
What you describe sounds like a security program is blocking Lightburn from sending data. It works once and then the heuristics in the security software block any further attempts to send data. Or it could be any number of software conflicts or misconfigurations.
Today I tested with the security software off and there is no differents. I also saw that the filelist not works on the moment that I cannot send a file.
Your could try pinging the laser ip from the computer you have lightburn on.
Click start then type cmd , then click command prompt.
And in the black box type
ping 192.168.1.100 -n 100
Your laser might have a different IP address just change 192.168.1.100 to what ever your lasers ip is.
If you get packet loss, that might be the issue.
If your computer is connected with WiFi try connecting using an Ethernet cable.
If you are connected using a Ethernet cable try replacing the Ethernet cable
Today I find out that when I hit the refresh button in LB many times (20 or more) that I can send a new file to the laser. On a certain moment the list will refresch, is first empty and after some more hits there is a new list. Thats the moment I can send a new file.
