dab55
(Douglas Brown)
May 8, 2022, 11:26pm
#1
I have a project with a single cut layer derived from a SVG image. Before sending the job to the laser I group all ellements of the image.
The job completes however, the ellements of the image are not correctly positioned as you can see from the attached image.
If I rung the job using LaserGRBL and the same SVG file and settings It completes corretly, as shown inthe attached image.
This tells me that I do not have a mechanical issue with my Chinese laser engraver or the settings on the DLC V2.0 controll board.
The problem must be in my Lightburn settings I would greatly appreciate some guidance on this issue.
What is the source of the SVG that you are importing into LightBurn?
Are you able to provide the following?
Screenshot of Preview in LightBurn with this design
Actual SVG file
Actual LightBurn .lbrn file with design ready-to-burn
dab55
(Douglas Brown)
May 9, 2022, 6:09am
#3
please find attached files as requested
AirTag_Sleeve CORRECTED.lbrn2 (62.9 KB)
dab55
(Douglas Brown)
May 9, 2022, 6:32am
#4
These are the gcode files sent to the controller from Lightburn and LaserGRBL. I will send lightburn file attached to this post and The LaserGRBL file attached to a seperate post.
Lightburn
; LightBurn 1.1.04
; GRBL device profile, current position
; Bounds: X-38.37 Y-56.87 to X38.37 Y56.87
G00 G17 G40 G21 G54
G91
M4
; Cut @ 600 mm/min, 55% power
M8
G0 X3.914Y-1.632
; Layer C00
G1 X0.049Y-0.243S550F600
G1 X0.134Y-0.198
G1 X0.198Y-0.134
G1 X0.243Y-0.049
G1 X0.243Y0.049
G1 X0.199Y0.134
G1 X0.134Y0.198
G1 X0.049Y0.243
G1 X-0.049Y0.243
G1 X-0.134Y0.199
G1 X-0.199Y0.133
G1 X-0.243Y0.049
G1 X-0.243Y-0.049
G1 X-0.198Y-0.133
G1 X-0.134Y-0.199
G1 X-0.049Y-0.243
G0 X3.213Y1.721
G1 X0.049Y-0.243
G1 X0.134Y-0.198
G1 X0.199Y-0.134
G1 X0.243Y-0.049
G1 X0.243Y0.049
G1 X0.198Y0.134
G1 X0.134Y0.198
G1 X0.049Y0.243
G1 X-0.049Y0.243
G1 X-0.134Y0.199
G1 X-0.198Y0.133
G1 X-0.243Y0.05
G1 X-0.243Y-0.05
G1 X-0.199Y-0.133
G1 X-0.134Y-0.199
G1 X-0.049Y-0.243
G0 X3.49Y1.057
G1 X0.049Y-0.243
G1 X0.133Y-0.198
G1 X0.199Y-0.134
G1 X0.243Y-0.049
G1 X0.243Y0.049
G1 X0.198Y0.134
G1 X0.134Y0.198
G1 X0.049Y0.243
G1 X-0.049Y0.243
G1 X-0.134Y0.198
G1 X-0.198Y0.134
G1 X-0.243Y0.049
G1 X-0.243Y-0.049
G1 X-0.199Y-0.134
G1 X-0.133Y-0.198
G1 X-0.049Y-0.243
G0 X3.628Y0.354
G1 X0.05Y-0.243
G1 X0.133Y-0.199
G1 X0.199Y-0.134
G1 X0.243Y-0.049
G1 X0.243Y0.049
G1 X0.198Y0.134
G1 X0.134Y0.199
G1 X0.049Y0.243
G1 X-0.049Y0.243
G1 X-0.134Y0.198
G1 X-0.198Y0.134
G1 X-0.243Y0.049
G1 X-0.243Y-0.049
G1 X-0.199Y-0.134
G1 X-0.133Y-0.198
G1 X-0.05Y-0.243
G0 X3.628Y-0.354
G1 X0.05Y-0.243
G1 X0.133Y-0.198
G1 X0.199Y-0.134
G1 X0.243Y-0.049
G1 X0.243Y0.049
G1 X0.198Y0.134
G1 X0.134Y0.198
G1 X0.049Y0.243
G1 X-0.049Y0.243
G1 X-0.134Y0.198
G1 X-0.198Y0.134
G1 X-0.243Y0.049
G1 X-0.243Y-0.049
G1 X-0.199Y-0.134
G1 X-0.133Y-0.198
G1 X-0.05Y-0.243
G0 X3.49Y-1.057
G1 X0.049Y-0.243
G1 X0.133Y-0.198
G1 X0.199Y-0.134
G1 X0.243Y-0.049
G1 X0.243Y0.049
G1 X0.198Y0.134
G1 X0.134Y0.198
G1 X0.049Y0.243
G1 X-0.049Y0.243
G1 X-0.134Y0.199
G1 X-0.198Y0.133
G1 X-0.243Y0.05
G1 X-0.243Y-0.05
G1 X-0.199Y-0.133
G1 X-0.133Y-0.199
G1 X-0.049Y-0.243
G0 X3.213Y-1.721
G1 X0.049Y-0.243
G1 X0.134Y-0.198
G1 X0.198Y-0.134
G1 X0.243Y-0.049
G1 X0.243Y0.049
G1 X0.199Y0.134
G1 X0.133Y0.198
G1 X0.05Y0.243
G1 X-0.05Y0.243
G1 X-0.133Y0.199
G1 X-0.199Y0.133
G1 X-0.243Y0.049
G1 X-0.243Y-0.049
G1 X-0.198Y-0.133
G1 X-0.134Y-0.199
G1 X-0.049Y-0.243
G0 X2.817Y-2.314
G1 X0.049Y-0.243
G1 X0.134Y-0.199
G1 X0.198Y-0.134
G1 X0.243Y-0.049
G1 X0.243Y0.049
G1 X0.199Y0.134
G1 X0.133Y0.199
G1 X0.049Y0.243
G1 X-0.049Y0.243
G1 X-0.133Y0.198
G1 X-0.199Y0.134
G1 X-0.243Y0.049
G1 X-0.243Y-0.049
G1 X-0.198Y-0.134
G1 X-0.134Y-0.198
G1 X-0.049Y-0.243
G0 X2.314Y-2.817
G1 X0.049Y-0.243
G1 X0.134Y-0.199
G1 X0.199Y-0.133
G1 X0.243Y-0.049
G1 X0.243Y0.049
G1 X0.198Y0.133
G1 X0.134Y0.199
G1 X0.049Y0.243
G1 X-0.049Y0.243
G1 X-0.134Y0.198
G1 X-0.198Y0.134
G1 X-0.243Y0.049
G1 X-0.243Y-0.049
G1 X-0.199Y-0.134
G1 X-0.134Y-0.198
G1 X-0.049Y-0.243
G0 X1.721Y-3.214
G1 X0.049Y-0.243
G1 X0.134Y-0.198
G1 X0.199Y-0.134
G1 X0.243Y-0.049
G1 X0.243Y0.049
G1 X0.198Y0.134
G1 X0.134Y0.198
G1 X0.049Y0.243
G1 X-0.049Y0.243
G1 X-0.134Y0.199
G1 X-0.198Y0.134
G1 X-0.243Y0.049
G1 X-0.243Y-0.049
G1 X-0.199Y-0.134
G1 X-0.134Y-0.199
G1 X-0.049Y-0.243
G0 X1.057Y-3.489
G1 X0.049Y-0.243
G1 X0.134Y-0.198
G1 X0.198Y-0.134
G1 X0.243Y-0.049
G1 X0.243Y0.049
G1 X0.199Y0.134
G1 X0.134Y0.198
G1 X0.049Y0.243
G1 X-0.049Y0.243
G1 X-0.134Y0.199
G1 X-0.199Y0.134
G1 X-0.243Y0.049
G1 X-0.243Y-0.049
G1 X-0.198Y-0.134
G1 X-0.134Y-0.199
G1 X-0.049Y-0.243
G0 X0.355Y-3.629
G1 X0.049Y-0.243
G1 X0.134Y-0.198
G1 X0.198Y-0.134
G1 X0.243Y-0.049
G1 X0.243Y0.049
G1 X0.199Y0.134
G1 X0.133Y0.198
G1 X0.049Y0.243
G1 X-0.049Y0.243
G1 X-0.133Y0.199
G1 X-0.199Y0.134
G1 X-0.243Y0.049
G1 X-0.243Y-0.049
G1 X-0.198Y-0.134
G1 X-0.134Y-0.199
G1 X-0.049Y-0.243
G0 X-0.355Y-3.628
G1 X0.049Y-0.243
G1 X0.134Y-0.198
G1 X0.198Y-0.134
G1 X0.243Y-0.049
G1 X0.243Y0.049
G1 X0.199Y0.134
G1 X0.134Y0.198
G1 X0.049Y0.243
G1 X-0.049Y0.243
G1 X-0.134Y0.199
G1 X-0.199Y0.134
G1 X-0.243Y0.049
G1 X-0.243Y-0.049
G1 X-0.198Y-0.134
G1 X-0.134Y-0.199
G1 X-0.049Y-0.243
G0 X-1.057Y-3.489
G1 X0.049Y-0.243
G1 X0.134Y-0.198
G1 X0.199Y-0.134
G1 X0.243Y-0.049
G1 X0.243Y0.049
G1 X0.198Y0.134
G1 X0.134Y0.198
G1 X0.049Y0.243
G1 X-0.049Y0.243
G1 X-0.134Y0.199
G1 X-0.198Y0.134
G1 X-0.243Y0.049
G1 X-0.243Y-0.049
G1 X-0.199Y-0.134
G1 X-0.134Y-0.199
G1 X-0.049Y-0.243
G0 X-29.208Y7.118
G1 X0.016Y-0.651
G1 X0.049Y-0.642
G1 X0.081Y-0.633
G1 X0.111Y-0.623
G1 X0.141Y-0.612
G1 X0.17Y-0.601
G1 X0.199Y-0.587
G1 X0.227Y-0.575
G1 X0.253Y-0.56
G1 X0.28Y-0.546
G1 X0.304Y-0.529
G1 X0.329Y-0.514
G1 X0.353Y-0.496
G1 X0.375Y-0.478
G1 X0.398Y-0.459
G1 X0.419Y-0.439
G1 X0.439Y-0.419
G1 X0.459Y-0.397
G1 X0.478Y-0.376
G1 X0.496Y-0.352
G1 X0.513Y-0.33
G1 X0.53Y-0.304
G1 X0.546Y-0.279
G1 X0.56Y-0.254
G1 X0.574Y-0.226
G1 X0.588Y-0.199
G1 X0.6Y-0.171
G1 X0.612Y-0.141
G1 X0.623Y-0.111
G1 X0.633Y-0.081
G1 X0.643Y-0.048
G1 X0.651Y-0.017
G1 X0.651Y0.017
G1 X0.642Y0.048
G1 X0.633Y0.081
G1 X0.623Y0.111
G1 X0.612Y0.141
G1 X0.601Y0.171
G1 X0.587Y0.199
G1 X0.575Y0.226
G1 X0.56Y0.254
G1 X0.546Y0.279
G1 X0.529Y0.304
G1 X0.514Y0.33
G1 X0.495Y0.352
G1 X0.478Y0.376
G1 X0.459Y0.397
G1 X0.44Y0.419
G1 X0.419Y0.439
G1 X0.397Y0.459
G1 X0.376Y0.478
G1 X0.352Y0.496
G1 X0.329Y0.514
G1 X0.305Y0.529
G1 X0.279Y0.546
G1 X0.254Y0.56
G1 X0.226Y0.575
G1 X0.199Y0.587
G1 X0.17Y0.601
G1 X0.142Y0.612
G1 X0.111Y0.623
G1 X0.08Y0.633
G1 X0.049Y0.642
G1 X0.017Y0.651
G1 X-0.017Y0.651
G1 X-0.049Y0.642
G1 X-0.08Y0.634
G1 X-0.111Y0.623
G1 X-0.142Y0.612
G1 X-0.17Y0.6
G1 X-0.199Y0.588
G1 X-0.226Y0.574
G1 X-0.254Y0.56
G1 X-0.279Y0.546
G1 X-0.305Y0.53
G1 X-0.329Y0.513
G1 X-0.352Y0.496
G1 X-0.376Y0.478
G1 X-0.397Y0.459
G1 X-0.419Y0.439
G1 X-0.44Y0.419
G1 X-0.459Y0.397
G1 X-0.478Y0.376
G1 X-0.495Y0.353
G1 X-0.514Y0.329
G1 X-0.529Y0.304
G1 X-0.546Y0.28
G1 X-0.56Y0.253
G1 X-0.575Y0.226
G1 X-0.587Y0.199
G1 X-0.601Y0.171
G1 X-0.612Y0.141
G1 X-0.623Y0.111
G1 X-0.633Y0.081
G1 X-0.642Y0.049
G1 X-0.651Y0.016
G1 X-0.651Y-0.016
G1 X-0.643Y-0.049
G1 X-0.633Y-0.081
G1 X-0.623Y-0.111
G1 X-0.612Y-0.141
G1 X-0.6Y-0.171
G1 X-0.588Y-0.199
G1 X-0.574Y-0.226
G1 X-0.56Y-0.253
G1 X-0.546Y-0.28
G1 X-0.53Y-0.304
G1 X-0.513Y-0.329
G1 X-0.496Y-0.353
G1 X-0.478Y-0.376
G1 X-0.459Y-0.397
G1 X-0.439Y-0.419
G1 X-0.419Y-0.439
G1 X-0.398Y-0.459
G1 X-0.375Y-0.478
G1 X-0.353Y-0.496
G1 X-0.329Y-0.513
G1 X-0.304Y-0.53
G1 X-0.28Y-0.546
G1 X-0.253Y-0.56
G1 X-0.227Y-0.574
G1 X-0.199Y-0.588
G1 X-0.17Y-0.6
G1 X-0.141Y-0.612
G1 X-0.111Y-0.623
G1 X-0.081Y-0.634
G1 X-0.049Y-0.642
G1 X-0.016Y-0.651
G0 X-6.569Y-0.001
G1 X0.049Y-0.243
G1 X0.134Y-0.198
G1 X0.198Y-0.134
G1 X0.244Y-0.049
G1 X0.243Y0.049
G1 X0.198Y0.134
G1 X0.134Y0.198
G1 X0.049Y0.243
G1 X-0.049Y0.243
G1 X-0.134Y0.199
G1 X-0.198Y0.134
G1 X-0.243Y0.049
G1 X-0.244Y-0.049
G1 X-0.198Y-0.134
G1 X-0.134Y-0.199
G1 X-0.049Y-0.243
G0 X0.354Y-3.628
G1 X0.049Y-0.243
G1 X0.134Y-0.198
G1 X0.198Y-0.134
G1 X0.243Y-0.049
G1 X0.243Y0.049
G1 X0.199Y0.134
G1 X0.133Y0.198
G1 X0.049Y0.243
G1 X-0.049Y0.243
G1 X-0.133Y0.199
G1 X-0.199Y0.134
G1 X-0.243Y0.049
G1 X-0.243Y-0.049
G1 X-0.198Y-0.134
G1 X-0.134Y-0.199
G1 X-0.049Y-0.243
G0 X1.057Y-3.489
G1 X0.049Y-0.243
G1 X0.134Y-0.198
G1 X0.198Y-0.134
G1 X0.243Y-0.049
G1 X0.243Y0.049
G1 X0.198Y0.134
G1 X0.134Y0.198
G1 X0.049Y0.243
G1 X-0.049Y0.243
G1 X-0.134Y0.199
G1 X-0.198Y0.134
G1 X-0.243Y0.049
G1 X-0.243Y-0.049
G1 X-0.198Y-0.134
G1 X-0.134Y-0.199
G1 X-0.049Y-0.243
G0 X-1.057Y10.746
G1 X0.049Y-0.243
G1 X0.134Y-0.198
G1 X0.198Y-0.134
G1 X0.243Y-0.049
G1 X0.243Y0.049
G1 X0.199Y0.134
G1 X0.133Y0.198
G1 X0.049Y0.243
G1 X-0.049Y0.243
G1 X-0.133Y0.199
G1 X-0.199Y0.134
G1 X-0.243Y0.049
G1 X-0.243Y-0.049
G1 X-0.198Y-0.134
G1 X-0.134Y-0.199
G1 X-0.049Y-0.243
G0 X1.057Y3.489
G1 X0.049Y-0.243
G1 X0.134Y-0.198
G1 X0.198Y-0.134
G1 X0.243Y-0.049
G1 X0.243Y0.049
G1 X0.198Y0.134
G1 X0.134Y0.198
G1 X0.049Y0.243
G1 X-0.049Y0.243
G1 X-0.134Y0.199
G1 X-0.198Y0.134
G1 X-0.243Y0.049
G1 X-0.243Y-0.049
G1 X-0.198Y-0.134
G1 X-0.134Y-0.199
G1 X-0.049Y-0.243
G0 X1.721Y3.214
G1 X0.049Y-0.243
G1 X0.134Y-0.199
G1 X0.198Y-0.133
G1 X0.243Y-0.049
G1 X0.243Y0.049
G1 X0.199Y0.133
G1 X0.133Y0.199
G1 X0.049Y0.243
G1 X-0.049Y0.243
G1 X-0.133Y0.198
G1 X-0.199Y0.134
G1 X-0.243Y0.049
G1 X-0.243Y-0.049
G1 X-0.198Y-0.134
G1 X-0.134Y-0.198
G1 X-0.049Y-0.243
G0 X2.314Y2.817
G1 X0.049Y-0.243
G1 X0.134Y-0.199
G1 X0.198Y-0.134
G1 X0.243Y-0.049
G1 X0.243Y0.049
G1 X0.199Y0.134
G1 X0.134Y0.199
G1 X0.049Y0.243
G1 X-0.049Y0.243
G1 X-0.134Y0.198
G1 X-0.199Y0.134
G1 X-0.243Y0.049
G1 X-0.243Y-0.049
G1 X-0.198Y-0.134
G1 X-0.134Y-0.198
G1 X-0.049Y-0.243
G0 X-7.011Y7.574
G1 X-0.049Y0.243
G1 X-0.133Y0.199
G1 X-0.199Y0.134
G1 X-0.243Y0.049
G1 X-0.243Y-0.049
G1 X-0.198Y-0.134
G1 X-0.134Y-0.199
G1 X-0.049Y-0.243
G1 X0.049Y-0.243
G1 X0.134Y-0.198
G1 X0.198Y-0.134
G1 X0.243Y-0.049
G1 X0.243Y0.049
G1 X0.199Y0.134
G1 X0.133Y0.198
G1 X0.049Y0.243
G0 X-3.213Y-1.721
G1 X-0.049Y0.243
G1 X-0.134Y0.199
G1 X-0.198Y0.134
G1 X-0.243Y0.049
G1 X-0.243Y-0.049
G1 X-0.199Y-0.134
G1 X-0.134Y-0.199
G1 X-0.049Y-0.243
G1 X0.049Y-0.243
G1 X0.134Y-0.198
G1 X0.199Y-0.134
G1 X0.243Y-0.049
G1 X0.243Y0.049
G1 X0.198Y0.134
G1 X0.134Y0.198
G1 X0.049Y0.243
G0 X-3.489Y-1.056
G1 X-0.049Y0.243
G1 X-0.134Y0.198
G1 X-0.198Y0.134
G1 X-0.243Y0.049
G1 X-0.243Y-0.049
G1 X-0.199Y-0.134
G1 X-0.134Y-0.198
G1 X-0.049Y-0.243
G1 X0.049Y-0.244
G1 X0.134Y-0.198
G1 X0.199Y-0.134
G1 X0.243Y-0.049
G1 X0.243Y0.049
G1 X0.198Y0.134
G1 X0.134Y0.198
G1 X0.049Y0.244
G0 X-3.629Y-0.354
G1 X-0.049Y0.243
G1 X-0.134Y0.198
G1 X-0.198Y0.134
G1 X-0.243Y0.049
G1 X-0.243Y-0.049
G1 X-0.199Y-0.134
G1 X-0.134Y-0.198
G1 X-0.049Y-0.243
G1 X0.049Y-0.243
G1 X0.134Y-0.199
G1 X0.199Y-0.133
G1 X0.243Y-0.049
G1 X0.243Y0.049
G1 X0.198Y0.133
G1 X0.134Y0.199
G1 X0.049Y0.243
G0 X-3.628Y0.354
G1 X-0.049Y0.243
G1 X-0.134Y0.198
G1 X-0.198Y0.134
G1 X-0.243Y0.049
G1 X-0.243Y-0.049
G1 X-0.199Y-0.134
G1 X-0.134Y-0.198
G1 X-0.049Y-0.243
G1 X0.049Y-0.244
G1 X0.134Y-0.198
G1 X0.199Y-0.134
G1 X0.243Y-0.049
G1 X0.243Y0.049
G1 X0.198Y0.134
G1 X0.134Y0.198
G1 X0.049Y0.244
G0 X-3.489Y1.056
G1 X-0.049Y0.243
G1 X-0.134Y0.199
G1 X-0.198Y0.134
G1 X-0.243Y0.049
G1 X-0.243Y-0.049
G1 X-0.199Y-0.134
G1 X-0.134Y-0.199
G1 X-0.049Y-0.243
G1 X0.049Y-0.243
G1 X0.134Y-0.198
G1 X0.199Y-0.134
G1 X0.243Y-0.049
G1 X0.243Y0.049
G1 X0.198Y0.134
G1 X0.134Y0.198
G1 X0.049Y0.243
G0 X-3.214Y1.721
G1 X-0.049Y0.243
G1 X-0.133Y0.199
G1 X-0.199Y0.134
G1 X-0.243Y0.049
G1 X-0.243Y-0.049
G1 X-0.198Y-0.134
G1 X-0.134Y-0.199
G1 X-0.049Y-0.243
G1 X0.049Y-0.243
G1 X0.134Y-0.198
G1 X0.198Y-0.134
G1 X0.243Y-0.049
G1 X0.243Y0.049
G1 X0.199Y0.134
G1 X0.133Y0.198
G1 X0.049Y0.243
G0 X-2.816Y2.315
G1 X-0.049Y0.243
G1 X-0.134Y0.198
G1 X-0.199Y0.134
G1 X-0.243Y0.049
G1 X-0.243Y-0.049
G1 X-0.198Y-0.134
G1 X-0.134Y-0.198
G1 X-0.049Y-0.243
G1 X0.049Y-0.243
G1 X0.134Y-0.199
G1 X0.198Y-0.133
G1 X0.243Y-0.049
G1 X0.243Y0.049
G1 X0.199Y0.133
G1 X0.134Y0.199
G1 X0.049Y0.243
G0 X-2.315Y2.817
G1 X-0.049Y0.243
G1 X-0.134Y0.198
G1 X-0.198Y0.134
G1 X-0.243Y0.049
G1 X-0.243Y-0.049
G1 X-0.199Y-0.134
G1 X-0.133Y-0.198
G1 X-0.049Y-0.243
G1 X0.049Y-0.243
G1 X0.133Y-0.199
G1 X0.199Y-0.134
G1 X0.243Y-0.049
G1 X0.243Y0.049
G1 X0.198Y0.134
G1 X0.134Y0.199
G1 X0.049Y0.243
G0 X-1.721Y3.213
G1 X-0.049Y0.243
G1 X-0.134Y0.199
G1 X-0.198Y0.133
G1 X-0.243Y0.049
G1 X-0.243Y-0.049
G1 X-0.199Y-0.133
G1 X-0.133Y-0.199
G1 X-0.049Y-0.243
G1 X0.049Y-0.243
G1 X0.133Y-0.198
G1 X0.199Y-0.134
G1 X0.243Y-0.049
G1 X0.243Y0.049
G1 X0.198Y0.134
G1 X0.134Y0.198
G1 X0.049Y0.243
G0 X-1.057Y3.489
G1 X-0.049Y0.243
G1 X-0.133Y0.199
G1 X-0.199Y0.133
G1 X-0.243Y0.049
G1 X-0.243Y-0.049
G1 X-0.198Y-0.133
G1 X-0.134Y-0.199
G1 X-0.049Y-0.243
G1 X0.049Y-0.243
G1 X0.134Y-0.198
G1 X0.198Y-0.134
G1 X0.243Y-0.049
G1 X0.243Y0.049
G1 X0.199Y0.134
G1 X0.133Y0.198
G1 X0.049Y0.243
G0 X-0.354Y3.629
G1 X-0.049Y0.243
G1 X-0.134Y0.199
G1 X-0.199Y0.133
G1 X-0.243Y0.049
G1 X-0.243Y-0.049
G1 X-0.198Y-0.133
G1 X-0.134Y-0.199
G1 X-0.049Y-0.243
G1 X0.049Y-0.243
G1 X0.134Y-0.198
G1 X0.198Y-0.134
G1 X0.243Y-0.049
G1 X0.243Y0.049
G1 X0.199Y0.134
G1 X0.134Y0.198
G1 X0.049Y0.243
G0 X0.354Y3.628
G1 X-0.049Y0.243
G1 X-0.133Y0.199
G1 X-0.199Y0.133
G1 X-0.243Y0.049
G1 X-0.243Y-0.049
G1 X-0.198Y-0.133
G1 X-0.134Y-0.199
G1 X-0.049Y-0.243
G1 X0.049Y-0.243
G1 X0.134Y-0.198
G1 X0.198Y-0.134
G1 X0.243Y-0.049
G1 X0.243Y0.049
G1 X0.199Y0.134
G1 X0.133Y0.198
G1 X0.049Y0.243
G0 X1.057Y3.489
G1 X-0.049Y0.243
G1 X-0.134Y0.199
G1 X-0.198Y0.133
G1 X-0.243Y0.049
G1 X-0.243Y-0.049
G1 X-0.199Y-0.133
G1 X-0.133Y-0.199
G1 X-0.049Y-0.243
G1 X0.049Y-0.243
G1 X0.133Y-0.198
G1 X0.199Y-0.134
G1 X0.243Y-0.049
G1 X0.243Y0.049
G1 X0.198Y0.134
G1 X0.134Y0.198
G1 X0.049Y0.243
G0 X34.367Y0
G1 X-0.049Y0.243
G1 X-0.134Y0.199
G1 X-0.199Y0.133
G1 X-0.243Y0.049
G1 X-0.243Y-0.049
G1 X-0.198Y-0.133
G1 X-0.134Y-0.199
G1 X-0.049Y-0.243
G1 X0.049Y-0.243
G1 X0.134Y-0.198
G1 X0.198Y-0.134
G1 X0.243Y-0.049
G1 X0.243Y0.049
G1 X0.199Y0.134
G1 X0.134Y0.198
G1 X0.049Y0.243
G0 X1.057Y-3.489
G1 X-0.049Y0.243
G1 X-0.134Y0.199
G1 X-0.199Y0.133
G1 X-0.243Y0.049
G1 X-0.243Y-0.049
G1 X-0.198Y-0.133
G1 X-0.134Y-0.199
G1 X-0.049Y-0.243
G1 X0.049Y-0.243
G1 X0.134Y-0.198
G1 X0.198Y-0.134
G1 X0.243Y-0.049
G1 X0.243Y0.049
G1 X0.199Y0.134
G1 X0.134Y0.198
G1 X0.049Y0.243
G0 X0.353Y-3.628
G1 X-0.049Y0.243
G1 X-0.134Y0.199
G1 X-0.198Y0.133
G1 X-0.243Y0.049
G1 X-0.243Y-0.049
G1 X-0.199Y-0.133
G1 X-0.133Y-0.199
G1 X-0.049Y-0.243
G1 X0.049Y-0.243
G1 X0.133Y-0.198
G1 X0.199Y-0.134
G1 X0.243Y-0.049
G1 X0.243Y0.049
G1 X0.198Y0.134
G1 X0.134Y0.198
G1 X0.049Y0.243
G0 X-0.353Y-3.629
G1 X-0.049Y0.243
G1 X-0.134Y0.199
G1 X-0.199Y0.133
G1 X-0.243Y0.049
G1 X-0.243Y-0.049
G1 X-0.198Y-0.133
G1 X-0.134Y-0.199
G1 X-0.049Y-0.243
G1 X0.049Y-0.243
G1 X0.134Y-0.198
G1 X0.198Y-0.134
G1 X0.243Y-0.049
G1 X0.243Y0.049
G1 X0.199Y0.134
G1 X0.134Y0.198
G1 X0.049Y0.243
G0 X-1.057Y-3.489
G1 X-0.049Y0.243
G1 X-0.134Y0.199
G1 X-0.199Y0.133
G1 X-0.243Y0.049
G1 X-0.243Y-0.049
G1 X-0.198Y-0.133
G1 X-0.134Y-0.199
G1 X-0.049Y-0.243
G1 X0.049Y-0.243
G1 X0.134Y-0.198
G1 X0.198Y-0.134
G1 X0.243Y-0.049
G1 X0.243Y0.049
G1 X0.199Y0.134
G1 X0.134Y0.198
G1 X0.049Y0.243
G0 X-1.721Y-3.213
G1 X-0.049Y0.243
G1 X-0.134Y0.198
G1 X-0.199Y0.134
G1 X-0.243Y0.049
G1 X-0.243Y-0.049
G1 X-0.198Y-0.134
G1 X-0.134Y-0.198
G1 X-0.049Y-0.243
G1 X0.049Y-0.243
G1 X0.134Y-0.199
G1 X0.198Y-0.134
G1 X0.243Y-0.049
G1 X0.243Y0.049
G1 X0.199Y0.134
G1 X0.134Y0.199
G1 X0.049Y0.243
G0 X-2.315Y-2.817
G1 X-0.049Y0.243
G1 X-0.134Y0.198
G1 X-0.198Y0.134
G1 X-0.243Y0.049
G1 X-0.243Y-0.049
G1 X-0.198Y-0.134
G1 X-0.134Y-0.198
G1 X-0.049Y-0.243
G1 X0.049Y-0.243
G1 X0.134Y-0.199
G1 X0.198Y-0.133
G1 X0.243Y-0.049
G1 X0.243Y0.049
G1 X0.198Y0.133
G1 X0.134Y0.199
G1 X0.049Y0.243
G0 X4.886Y23.844
G1 X-0.331Y0.557
G1 X-0.349Y0.546
G1 X-0.365Y0.534
G1 X-0.383Y0.523
G1 X-0.635Y0.813
G1 X-0.674Y0.78
G1 X-0.711Y0.746
G1 X-0.747Y0.712
G1 X-0.793Y0.687
G1 X-0.817Y0.641
G1 X-0.633Y0.45
G1 X-0.64Y0.439
G1 X-0.732Y0.445
G1 X-0.749Y0.416
G1 X-0.766Y0.385
G1 X-0.781Y0.353
G1 X-0.112Y0.073
G1 X-0.089Y0.098
G1 X-0.061Y0.117
G1 X-0.031Y0.13
G1 X-0.014Y1.716
G1 X-0.071Y1.714
G1 X-0.055Y1.903
G1 X-0.039Y1.904
G1 X-0.059Y4.091
G1 X-0.165Y0.533
G1 X-0.199Y0.52
G1 X-0.231Y0.504
G1 X-0.262Y0.489
G1 X-0.293Y0.471
G1 X-0.322Y0.452
G1 X-0.352Y0.431
G1 X-0.379Y0.409
G1 X-0.519Y0.476
G1 X-0.551Y0.426
G1 X-0.574Y0.375
G1 X-0.637Y0.344
G1 X-0.59Y0.258
G1 X-0.66Y0.234
G1 X-0.661Y0.172
G1 X-0.671Y0.125
G1 X-0.633Y0.07
G1 X-0.68Y0.02
G1 X-0.672Y-0.038
G1 X-0.668Y-0.083
G1 X-0.625Y-0.137
G1 X-0.675Y-0.203
G1 X-0.582Y-0.23
G1 X-0.641Y-0.317
G1 X-0.413Y-0.247
G1 X-0.395Y-0.271
G1 X-0.376Y-0.295
G1 X-0.358Y-0.318
G1 X-0.336Y-0.339
G1 X-0.315Y-0.361
G1 X-0.292Y-0.38
G1 X-0.269Y-0.398
G1 X-0.403Y-0.705
G1 X-0.339Y-0.736
G1 X-0.274Y-0.763
G1 X-0.207Y-0.785
G1 X-0.082Y-0.382
G1 X0.081Y-3.117
G1 X0.048Y-3.118
G1 X-0.008Y-1.307
G1 X-0.066Y-1.306
G1 X-0.027Y-0.902
G1 X-0.008Y-0.903
G1 X-0.02Y-0.097
G1 X-0.016Y-0.048
G1 X-0.011Y-0.027
G1 X-0.103Y-0.141
G1 X-0.143Y-0.101
G1 X-0.777Y-0.351
G1 X-0.93Y-0.473
G1 X-1.117Y-0.652
G1 X-1.075Y-0.717
G1 X-1.03Y-0.781
G1 X-0.981Y-0.842
G1 X-0.571Y-0.537
G1 X-0.549Y-0.557
G1 X-0.528Y-0.575
G1 X-0.505Y-0.593
G1 X-0.483Y-0.609
G1 X-0.461Y-0.627
G1 X-0.437Y-0.642
G1 X-0.413Y-0.657
G1 X-0.39Y-0.672
G1 X-0.365Y-0.686
G1 X-0.34Y-0.699
G1 X-0.314Y-0.711
G1 X-0.29Y-0.724
G1 X-0.263Y-0.734
G1 X-0.237Y-0.746
G1 X-0.21Y-0.755
G1 X-0.246Y-1.062
G1 X-0.191Y-1.063
G1 X-0.137Y-1.07
G1 X-0.078Y-1.085
G1 X-0.031Y-1.087
G1 X0.03Y-1.103
G1 X0.079Y-1.1
G1 X0.137Y-1.074
G1 X0.191Y-1.059
G1 X0.246Y-1.066
G1 X0.282Y-0.996
G1 X0.336Y-1
G1 X0.386Y-0.981
G1 X0.547Y-1.182
G1 X0.613Y-1.15
G1 X0.331Y-0.555
G1 X0.346Y-0.546
G1 X0.363Y-0.535
G1 X0.378Y-0.524
G1 X0.637Y-0.812
G1 X0.678Y-0.782
G1 X0.713Y-0.75
G1 X0.567Y-0.547
G1 X0.586Y-0.526
G1 X0.603Y-0.502
G1 X0.62Y-0.479
G1 X0.636Y-0.456
G1 X0.652Y-0.432
G1 X0.667Y-0.408
G1 X0.681Y-0.383
G1 X0.694Y-0.358
G1 X0.708Y-0.333
G1 X0.719Y-0.307
G1 X0.731Y-0.281
G1 X0.741Y-0.254
G1 X0.751Y-0.228
G1 X0.761Y-0.2
G1 X0.769Y-0.173
G1 X1.036Y-0.183
G1 X1.078Y-0.137
G1 X1.117Y-0.086
G1 X1.09Y-0.027
G1 X1.093Y0.027
G1 X1.118Y0.086
G1 X1.078Y0.137
G1 X1.031Y0.183
G1 X1.066Y0.246
G1 X1.02Y0.289
G1 X0.977Y0.328
G1 X0.98Y0.387
G1 X0.946Y0.43
G1 X0.922Y0.473
G1 X0.898Y0.516
G1 X0.872Y0.558
G1 X0.844Y0.598
G1 X0.816Y0.639
G1 X0.785Y0.677
G1 X0.753Y0.715
G1 X0.54Y0.561
G1 X0.52Y0.58
G1 X0.498Y0.598
G1 X0.477Y0.614
G1 X0.454Y0.632
G1 X0.432Y0.647
G1 X0.409Y0.663
G1 X0.385Y0.677
G1 X0.472Y0.916
G1 X0.422Y0.94
G1 X0.387Y0.976
G1 X0.336Y1
G1 X0.289Y1.02
G1 X0.242Y1.043
G1 X0.192Y1.055
G1 X0.132Y1.078
G1 X0.086Y1.117
G1 X0.028Y1.082
G1 X-0.028Y1.105
G1 X-0.086Y1.118
G1 X-0.128Y1.046
G1 X-0.192Y1.063
G1 X-0.246Y1.062
G1 X-0.281Y1
G1 X-0.336Y0.996
G1 X-0.387Y0.981
G1 X-0.263Y0.597
G1 X-0.28Y0.588
G1 X-0.298Y0.58
G1 X-0.315Y0.571
G0 X-16.607Y17.955
G1 X-0.04Y0.402
G1 X-0.117Y0.375
G1 X-0.184Y0.34
G1 X-0.244Y0.295
G1 X-0.295Y0.244
G1 X-0.34Y0.185
G1 X-0.375Y0.116
G1 X-0.402Y0.041
G1 X-0.403Y-0.041
G1 X-0.375Y-0.116
G1 X-0.339Y-0.185
G1 X-0.296Y-0.244
G1 X-0.244Y-0.295
G1 X-0.184Y-0.34
G1 X-0.117Y-0.375
G1 X-0.04Y-0.402
G1 X0.04Y-0.403
G1 X0.117Y-0.375
G1 X0.184Y-0.339
G1 X0.244Y-0.296
G1 X0.296Y-0.244
G1 X0.339Y-0.184
G1 X0.375Y-0.116
G1 X0.403Y-0.041
G1 X0.402Y0.041
G1 X0.375Y0.116
G1 X0.34Y0.184
G1 X0.295Y0.244
G1 X0.244Y0.296
G1 X0.184Y0.339
G1 X0.117Y0.375
G1 X0.04Y0.403
G0 X27.636Y-93.487
G1 X0.041Y-0.403
G1 X0.116Y-0.375
G1 X0.184Y-0.339
G1 X0.244Y-0.296
G1 X0.296Y-0.244
G1 X0.339Y-0.184
G1 X0.375Y-0.117
G1 X0.403Y-0.04
G1 X0.402Y0.04
G1 X0.375Y0.117
G1 X0.34Y0.184
G1 X0.295Y0.244
G1 X0.244Y0.296
G1 X0.185Y0.339
G1 X0.116Y0.375
G1 X0.041Y0.403
G1 X-0.041Y0.402
G1 X-0.116Y0.375
G1 X-0.185Y0.34
G1 X-0.244Y0.295
G1 X-0.295Y0.244
G1 X-0.34Y0.184
G1 X-0.375Y0.117
G1 X-0.402Y0.04
G1 X-0.403Y-0.04
G1 X-0.375Y-0.117
G1 X-0.339Y-0.184
G1 X-0.296Y-0.244
G1 X-0.244Y-0.295
G1 X-0.184Y-0.34
G1 X-0.116Y-0.375
G1 X-0.041Y-0.402
G0 X3.202Y-11.089
G1 X0.438Y0.049
G1 X0.437Y0.061
G1 X0.436Y0.09
G1 X0.435Y0.101
G1 X0.679Y0.203
G1 X0.125Y0.043
G1 X0.36Y0.138
G1 X0.355Y0.147
G1 X0.377Y0.179
G1 X0.369Y0.192
G1 X0.477Y0.282
G1 X0.458Y0.307
G1 X0.44Y0.332
G1 X0.419Y0.357
G1 X0.399Y0.379
G1 X0.377Y0.402
G1 X0.354Y0.423
G1 X0.33Y0.444
G1 X0.302Y0.462
G1 X0.279Y0.475
G1 X0.255Y0.487
G1 X0.23Y0.499
G1 X0.206Y0.509
G1 X0.181Y0.52
G1 X0.156Y0.528
G1 X0.13Y0.536
G1 X0.105Y0.519
G1 X0.017Y0.138
G1 Y0.14
G1 X-0.008Y0.376
G1 X-0.031Y0.878
G1 X-0.025Y0.561
G1 X-0.021Y0.324
G1 X-0.012Y0.123
G1 X-0.016Y0.13
G1 X-0.006Y0.053
G1 Y0.076
G1 Y0.124
G1 Y0.193
G1 X0.02Y1.947
G1 X0.07Y4.367
G1 Y0.496
G1 X0.491Y0.243
G1 X0.482Y0.253
G1 X0.771Y0.439
G1 X0.752Y0.466
G1 X0.732Y0.493
G1 X0.713Y0.52
G1 X0.691Y0.544
G1 X0.67Y0.57
G1 X0.648Y0.594
G1 X0.625Y0.617
G1 X0.601Y0.64
G1 X0.578Y0.663
G1 X0.552Y0.684
G1 X0.528Y0.705
G1 X0.501Y0.725
G1 X0.474Y0.744
G1 X0.448Y0.764
G1 X0.419Y0.781
G1 X0.008Y0.02
G1 X0.383Y0.778
G1 X0.351Y0.792
G1 X0.213Y0.535
G1 X0.209Y0.536
G1 X0.344Y1.019
G1 X0.169Y0.593
G1 X0.167Y0.595
G1 X0.137Y0.567
G1 X0.125Y0.569
G1 X0.109Y0.579
G1 X0.098Y0.581
G1 X0.14Y1.098
G1 X0.09Y1.198
G1 X0.035Y1.201
G1 Y0.085
G1 X-0.031Y1.133
G1 X-0.04Y0.634
G1 X-0.054Y0.632
G1 X-0.14Y1.101
G1 X-0.097Y0.58
G1 X-0.11Y0.577
G1 X-0.129Y0.569
G1 X-0.133Y0.567
G1 X-0.315Y1.112
G1 X-0.365Y1.095
G1 X-0.205Y0.54
G1 X-0.217Y0.535
G1 X-0.118Y0.272
G1 X-0.12Y0.271
G1 X-0.012Y0.031
G1 X-0.226Y0.484
G1 X-0.135Y0.253
G1 X-0.123Y0.259
G1 X-0.008Y0.02
G1 X-0.246Y0.472
G1 X-0.418Y0.737
G1 X-0.444Y0.721
G1 X-0.469Y0.705
G1 X-0.536Y0.747
G1 X-0.348Y0.447
G1 X-0.351Y0.444
G1 X-0.692Y0.797
G1 X-0.405Y0.435
G1 X-0.415Y0.424
G1 X-0.379Y0.367
G1 X-0.938Y0.849
G1 X-0.981Y0.797
G1 X-1.023Y0.742
G1 X-1.121Y0.726
G1 X-0.921Y0.531
G1 X-0.265Y0.14
G1 X-0.267Y0.137
G1 X-0.019Y0.008
G1 X-0.477Y0.238
G1 X-0.035Y0.02
G1 X-0.484Y0.226
G1 X-0.032Y0.012
G1 X-0.27Y0.121
G1 X-0.272Y0.117
G1 X-0.535Y0.218
G1 X-0.54Y0.204
G1 X-1.023Y0.344
G1 X-0.589Y0.17
G1 X-0.591Y0.166
G1 X-1.062Y0.246
G1 X-1.164Y0.207
G1 X-1.172Y0.153
G1 X-0.597Y0.053
G1 X-0.599Y0.04
G1 X-0.078
G1 X-1.129Y0.032
G1 X-0.07
G1 X-1.133Y-0.028
G1 X-0.078
G1 X-0.598Y-0.044
G1 X-0.597Y-0.053
G1 X-1.102Y-0.141
G1 X-0.576Y-0.099
G1 X-0.576Y-0.104
G1 X-0.572Y-0.125
G1 X-0.569Y-0.137
G1 X-1.111Y-0.314
G1 X-1.096Y-0.366
G1 X-0.539Y-0.205
G1 X-0.535Y-0.217
G1 X-0.272Y-0.117
G1 X-0.271Y-0.121
G1 X-0.031Y-0.012
G1 X-0.485Y-0.226
G1 X-0.252Y-0.135
G1 X-0.259Y-0.123
G1 X-0.02Y-0.008
G1 X-0.266Y-0.137
G1 X-0.265Y-0.14
G1 X-0.922Y-0.531
G1 X-0.955Y-0.613
G1 X-0.924Y-0.657
G1 X-0.892Y-0.699
G1 X-0.858Y-0.742
G1 X-0.201Y-0.195
G1 X-0.209Y-0.188
G1 X-0.023Y-0.02
G1 X-0.55Y-0.541
G1 X-0.53Y-0.558
G1 X-0.512Y-0.575
G1 X-0.493Y-0.592
G1 X-0.473Y-0.607
G1 X-0.453Y-0.623
G1 X-0.433Y-0.637
G1 X-0.412Y-0.652
G1 X-0.039Y-0.058
G1 X-0.531Y-0.922
G1 X-0.14Y-0.265
G1 X-0.138Y-0.266
G1 X-0.007Y-0.02
G1 X-0.384Y-0.778
G1 X-0.351Y-0.792
G1 X-0.217Y-0.535
G1 X-0.205Y-0.54
G1 X-0.343Y-1.023
G1 X-0.174Y-0.59
G1 X-0.162Y-0.594
G1 X-0.134Y-0.567
G1 X-0.128Y-0.569
G1 X-0.195Y-1.082
G1 X-0.149Y-1.183
G1 X-0.094Y-1.188
G1 Y-0.079
G1 X-0.031Y-1.132
G1 Y-0.071
G1 X0.028Y-1.132
G1 Y-0.079
G1 X0.089Y-1.117
G1 X0.073Y-0.626
G1 X0.084Y-0.624
G1 X0.195Y-1.086
G1 X0.125Y-0.569
G1 X0.137Y-0.567
G1 X0.169Y-0.594
G1 X0.167Y-0.594
G1 X0.343Y-1.019
G1 X0.21Y-0.536
G1 X0.212Y-0.535
G1 X0.118Y-0.272
G1 X0.121Y-0.271
G1 X0.011Y-0.031
G1 X0.227Y-0.484
G1 X0.135Y-0.253
G1 X0.123Y-0.259
G1 X0.007Y-0.02
G1 X0.508Y-0.936
G1 X0.549Y-0.911
G1 X0.588Y-0.885
G1 X0.627Y-0.857
G1 X0.665Y-0.828
G1 X0.702Y-0.798
G1 X0.737Y-0.766
G1 X0.773Y-0.733
G1 X0.797Y-0.692
G1 X0.443Y-0.352
G1 X0.447Y-0.347
G1 X0.697Y-0.502
G1 X0.714Y-0.479
G1 X0.588Y-0.366
G1 X0.6Y-0.348
G1 X0.61Y-0.33
G1 X0.62Y-0.311
G1 X0.013Y-1.501
G1 X0.018Y-1.501
G1 X0.207Y-7.424
G1 X0.019Y-0.211
G1 X0.047Y-0.207
G1 X0.17Y-0.552
G1 X0.198Y-0.541
G1 X0.227Y-0.529
G1 X0.254Y-0.517
G1 X0.281Y-0.501
G1 X0.307Y-0.487
G1 X0.334Y-0.471
G1 X0.358Y-0.453
G1 X0.321Y-0.362
G1 X0.339Y-0.345
G1 X0.318Y-0.3
G1 X0.327Y-0.289
G1 X0.582Y-0.45
G1 X0.379Y-0.255
G1 X0.386Y-0.245
G1 X0.397Y-0.221
G1 X0.404Y-0.208
G1 X0.357Y-0.158
G1 X0.358Y-0.155
G1 X0.415Y-0.152
G1 X0.421Y-0.137
G1 X0.75Y-0.199
G1 X0.376Y-0.076
G1 X0.378Y-0.065
G1 X0.411Y-0.05
G1 X0.413Y-0.04
G1 X0.41Y-0.022
G1 X0.41
G1 X0.118
G1 X0.707Y0.03
M9
G1 S0
M5
; return to starting pos
G0 X-16.02Y56.834
M2
dab55
(Douglas Brown)
May 9, 2022, 6:34am
#5
The LaserGRBL gcode file
;G90 (use absolute coordinates)
M4 S0
S0
G1X110.822Y-523.268F1000
S200
Y-523.095F1000
X110.752Y-522.939
X110.639Y-522.826
X110.526Y-522.713
X110.37Y-522.643
X110.197
X110.025
X109.869Y-522.713
X109.756Y-522.826
X109.643Y-522.939
X109.573Y-523.095
Y-523.268
Y-523.44
X109.643Y-523.596
X109.756Y-523.709
X109.869Y-523.822
X110.025Y-523.892
X110.197
X110.37
X110.526Y-523.822
X110.639Y-523.709
X110.752Y-523.596
X110.822Y-523.44
Y-523.268
S0
X175.368Y-549.122
S200
Y-549.294F1000
X175.438Y-549.451
X175.551Y-549.564
X175.664Y-549.677
X175.82Y-549.746
X175.993
X176.165
X176.321Y-549.677
X176.434Y-549.564
X176.547Y-549.451
X176.617Y-549.294
Y-549.122
Y-548.95
X176.547Y-548.794
X176.434Y-548.681
X176.321Y-548.568
X176.165Y-548.498
X175.993
X175.82
X175.664Y-548.568
X175.551Y-548.681
X175.438Y-548.794
X175.368Y-548.95
Y-549.122
S0
X108.044Y-516.565
S200
Y-516.393F1000
X107.974Y-516.237
X107.861Y-516.124
X107.748Y-516.011
X107.592Y-515.941
X107.419
X107.247
X107.091Y-516.011
X106.978Y-516.124
X106.865Y-516.237
X106.795Y-516.393
Y-516.565
Y-516.738
X106.865Y-516.894
X106.978Y-517.007
X107.091Y-517.12
X107.247Y-517.19
X107.419
X107.592
X107.748Y-517.12
X107.861Y-517.007
X107.974Y-516.894
X108.044Y-516.738
Y-516.565
S0
X156.774Y-530.528
S200
Y-530.7F1000
X156.844Y-530.856
X156.957Y-530.969
X157.07Y-531.082
X157.226Y-531.152
X157.399
X157.571
X157.727Y-531.082
X157.84Y-530.969
X157.953Y-530.856
X158.023Y-530.7
Y-530.528
Y-530.355
X157.953Y-530.199
X157.84Y-530.086
X157.727Y-529.973
X157.571Y-529.903
X157.399
X157.226
X157.07Y-529.973
X156.957Y-530.086
X156.844Y-530.199
X156.774Y-530.355
Y-530.528
S0
X138.18Y-549.122
S200
Y-549.294F1000
X138.25Y-549.451
X138.363Y-549.564
X138.476Y-549.677
X138.632Y-549.746
X138.804
X138.976
X139.133Y-549.677
X139.246Y-549.564
X139.359Y-549.451
X139.428Y-549.294
Y-549.122
Y-548.95
X139.359Y-548.794
X139.246Y-548.681
X139.133Y-548.568
X138.976Y-548.498
X138.804
X138.632
X138.476Y-548.568
X138.363Y-548.681
X138.25Y-548.794
X138.18Y-548.95
Y-549.122
S0
X173.957Y-542.004
S200
Y-542.176F1000
X174.027Y-542.333
X174.14Y-542.445
X174.253Y-542.558
X174.409Y-542.628
X174.581
X174.754
X174.91Y-542.558
X175.023Y-542.445
X175.136Y-542.333
X175.206Y-542.176
Y-542.004
Y-541.832
X175.136Y-541.676
X175.023Y-541.563
X174.91Y-541.45
X174.754Y-541.38
X174.581
X174.409
X174.253Y-541.45
X174.14Y-541.563
X174.027Y-541.676
X173.957Y-541.832
Y-542.004
S0
X144.317Y-502.24
S200
X143.888Y-501.491F1000
X143.411Y-500.769
X142.89Y-500.08
X142.479Y-499.528
X142.042Y-498.996
X141.58Y-498.487
X141.119Y-497.978
X140.632Y-497.492
X140.122Y-497.03
X139.329Y-496.342
X138.513Y-495.701
X138.093Y-495.398
X137.669Y-495.102
X137.239Y-494.813
X136.757Y-494.506
X136.263Y-494.218
X135.758Y-493.952
X135.253Y-493.685
X134.737Y-493.438
X134.212Y-493.213
X134.048Y-493.135
X133.937Y-492.976
X133.919Y-492.795
X133.929Y-491.651
X133.9Y-490.507
X133.833Y-489.365
X133.791Y-488.097
X133.76Y-486.828
X133.739Y-485.559
X133.681Y-481.467
X133.482Y-480.749
X133.194Y-480.061
X132.823Y-479.421
X132.453Y-478.781
X132.002Y-478.189
X131.478Y-477.658
X130.958Y-477.182
X130.407Y-476.756
X129.833Y-476.381
X129.196Y-476.037
X128.606Y-475.78
X127.946Y-475.545
X127.51Y-475.415
X127.065Y-475.316
X126.614Y-475.248
X125.981Y-475.178
X125.302Y-475.158
X124.853Y-475.169
X124.405Y-475.209
X123.962Y-475.28
X123.337Y-475.416
X122.661Y-475.619
X122.079Y-475.85
X121.438Y-476.166
X120.877Y-476.478
X120.36Y-476.859
X119.897Y-477.297
X119.434Y-477.736
X119.026Y-478.232
X118.685Y-478.776
X118.395Y-479.234
X118.147Y-479.716
X117.943Y-480.216
X117.738Y-480.716
X117.577Y-481.234
X117.462Y-481.764
X117.38Y-482.147
X117.444Y-484.225
X117.487Y-486.302
X117.509Y-488.381
X117.522Y-489.253
X117.497Y-490.125
X117.435Y-490.994
X117.41Y-491.596
X117.398Y-492.197
X117.399Y-492.799
X117.38Y-492.897
X117.372Y-492.916
X117.367Y-492.935
X117.36Y-492.953
X117.352Y-492.971
X117.299Y-493.076
X117.213Y-493.162
X117.106Y-493.213
X116.329Y-493.565
X115.399Y-494.037
X114.641Y-494.45
X113.909Y-494.907
X113.207Y-495.406
X112.505Y-495.906
X111.834Y-496.448
X111.196Y-497.03
X110.809Y-497.381
X110.435Y-497.746
X110.076Y-498.123
X109.717Y-498.5
X109.373Y-498.89
X109.043Y-499.291
X108.384Y-500.093
X107.784Y-500.94
X107.249Y-501.827
X106.714Y-502.713
X106.243Y-503.638
X105.84Y-504.595
X105.638Y-505.073
X105.454Y-505.559
X105.287Y-506.053
X105.121Y-506.546
X104.972Y-507.046
X104.841Y-507.553
X104.595Y-508.616
X104.403Y-509.678
X104.266Y-510.748
X104.199Y-511.47
X104.163Y-512.195
X104.157Y-512.92
X104.162Y-513.656
X104.198Y-514.391
X104.266Y-515.123
X104.403Y-516.198
X104.595Y-517.256
X104.841Y-518.323
X105.122Y-519.319
X105.458Y-520.319
X105.845Y-521.299
X106.187Y-522.098
X106.574Y-522.876
X107.005Y-523.631
X107.434Y-524.379
X107.908Y-525.1
X108.423Y-525.791
X109.059Y-526.604
X109.499Y-527.135
X109.963Y-527.646
X110.45Y-528.135
X110.822Y-528.508
X111.207Y-528.865
X111.603Y-529.208
X111.999Y-529.551
X112.408Y-529.878
X112.826Y-530.19
X113.664Y-530.813
X114.545Y-531.374
X115.462Y-531.868
X116.379Y-532.363
X117.332Y-532.79
X118.314Y-533.147
X118.805Y-533.326
X119.303Y-533.487
X119.807Y-533.629
X120.311Y-533.772
X120.821Y-533.896
X121.337Y-534.002
X122.372Y-534.186
X123.45Y-534.323
X124.567Y-534.408
X125.657Y-534.436
X126.751Y-534.408
X127.868Y-534.323
X128.946Y-534.186
X129.978Y-534.002
X131.044Y-533.756
X132.064Y-533.467
X133.04Y-533.139
X134.021Y-532.752
X134.658Y-532.481
X135.282Y-532.179
X135.889Y-531.849
X136.495Y-531.52
X137.086Y-531.161
X137.658Y-530.776
X138.231Y-530.39
X138.784Y-529.977
X139.318Y-529.539
X139.852Y-529.1
X140.365Y-528.636
X140.857Y-528.147
X141.591Y-527.411
X142.271Y-526.624
X142.891Y-525.793
X143.512Y-524.962
X144.074Y-524.087
X144.571Y-523.174
X144.903Y-522.572
X145.201Y-521.953
X145.466Y-521.319
X145.853Y-520.342
X146.189Y-519.342
X146.478Y-518.323
X146.72Y-517.28
X146.911Y-516.225
X147.044Y-515.147
X147.13Y-514.03
X147.157Y-512.948
X147.13Y-511.842
X147.044Y-510.725
X146.915Y-509.678
X146.724Y-508.616
X146.478Y-507.553
X146.196Y-506.553
X145.86Y-505.557
X145.474Y-504.576
X145.135Y-503.775
X144.749Y-502.995
X144.317Y-502.24
S0
X129.912Y-531.177
S200
Y-531.005F1000
X129.843Y-530.848
X129.73Y-530.736
X129.617Y-530.623
X129.46Y-530.553
X129.288
X129.116
X128.96Y-530.623
X128.847Y-530.736
X128.734Y-530.848
X128.664Y-531.005
Y-531.177
Y-531.349
X128.734Y-531.505
X128.847Y-531.618
X128.96Y-531.731
X129.116Y-531.801
X129.288
X129.46
X129.617Y-531.731
X129.73Y-531.618
X129.843Y-531.505
X129.912Y-531.349
Y-531.177
S0
X175.014Y-545.493
S200
Y-545.666F1000
X175.084Y-545.822
X175.197Y-545.935
X175.31Y-546.048
X175.466Y-546.117
X175.638
X175.811
X175.967Y-546.048
X176.08Y-545.935
X176.193Y-545.822
X176.262Y-545.666
Y-545.493
Y-545.321
X176.193Y-545.165
X176.08Y-545.052
X175.967Y-544.939
X175.811Y-544.869
X175.638
X175.466
X175.31Y-544.939
X175.197Y-545.052
X175.084Y-545.165
X175.014Y-545.321
Y-545.493
S0
X167.105Y-533.659
S200
Y-533.832F1000
X167.175Y-533.988
X167.288Y-534.101
X167.401Y-534.214
X167.557Y-534.284
X167.729
X167.901
X168.057Y-534.214
X168.17Y-534.101
X168.283Y-533.988
X168.353Y-533.832
Y-533.659
Y-533.487
X168.283Y-533.331
X168.17Y-533.218
X168.057Y-533.105
X167.901Y-533.035
X167.729
X167.557
X167.401Y-533.105
X167.288Y-533.218
X167.175Y-533.331
X167.105Y-533.487
Y-533.659
S0
X141.746Y-523.268
S200
Y-523.095F1000
X141.676Y-522.939
X141.563Y-522.826
X141.45Y-522.713
X141.294Y-522.643
X141.122
X140.95
X140.793Y-522.713
X140.68Y-522.826
X140.567Y-522.939
X140.498Y-523.095
Y-523.268
Y-523.44
X140.567Y-523.596
X140.68Y-523.709
X140.793Y-523.822
X140.95Y-523.892
X141.122
X141.294
X141.45Y-523.822
X141.563Y-523.709
X141.676Y-523.596
X141.746Y-523.44
Y-523.268
S0
X122.655Y-531.177
S200
Y-531.005F1000
X122.586Y-530.848
X122.473Y-530.736
X122.36Y-530.623
X122.204Y-530.553
X122.031
X121.859
X121.703Y-530.623
X121.59Y-530.736
X121.477Y-530.848
X121.407Y-531.005
Y-531.177
Y-531.349
X121.477Y-531.505
X121.59Y-531.618
X121.703Y-531.731
X121.859Y-531.801
X122.031
X122.204
X122.36Y-531.731
X122.473Y-531.618
X122.586Y-531.505
X122.655Y-531.349
Y-531.177
S0
X141.311Y-538.791
S200
Y-538.963F1000
X141.381Y-539.119
X141.494Y-539.232
X141.607Y-539.345
X141.763Y-539.415
X141.936
X142.108
X142.264Y-539.345
X142.377Y-539.232
X142.49Y-539.119
X142.56Y-538.963
Y-538.791
Y-538.618
X142.49Y-538.462
X142.377Y-538.349
X142.264Y-538.236
X142.108Y-538.166
X141.936
X141.763
X141.607Y-538.236
X141.494Y-538.349
X141.381Y-538.462
X141.311Y-538.618
Y-538.791
S0
X107.689Y-512.936
S200
Y-512.764F1000
X107.619Y-512.608
X107.506Y-512.495
X107.393Y-512.382
X107.237Y-512.312
X107.065
X106.892
X106.736Y-512.382
X106.623Y-512.495
X106.51Y-512.608
X106.44Y-512.764
Y-512.936
Y-513.109
X106.51Y-513.265
X106.623Y-513.378
X106.736Y-513.491
X106.892Y-513.561
X107.065
X107.237
X107.393Y-513.491
X107.506Y-513.378
X107.619Y-513.265
X107.689Y-513.109
Y-512.936
S0
X160.402Y-530.881
S200
Y-531.054F1000
X160.472Y-531.21
X160.585Y-531.323
X160.698Y-531.436
X160.854Y-531.506
X161.026
X161.199
X161.355Y-531.436
X161.468Y-531.323
X161.581Y-531.21
X161.651Y-531.054
Y-530.881
Y-530.709
X161.581Y-530.553
X161.468Y-530.44
X161.355Y-530.327
X161.199Y-530.257
X161.026
X160.854
X160.698Y-530.327
X160.585Y-530.44
X160.472Y-530.553
X160.402Y-530.709
Y-530.881
S0
X169.921Y-535.974
S200
Y-536.146F1000
X169.991Y-536.302
X170.104Y-536.415
X170.217Y-536.528
X170.373Y-536.598
X170.546
X170.718
X170.874Y-536.528
X170.987Y-536.415
X171.1Y-536.302
X171.17Y-536.146
Y-535.974
Y-535.801
X171.1Y-535.645
X170.987Y-535.532
X170.874Y-535.419
X170.718Y-535.349
X170.546
X170.373
X170.217Y-535.419
X170.104Y-535.532
X169.991Y-535.645
X169.921Y-535.801
Y-535.974
S0
X138.533Y-552.75
S200
Y-552.922F1000
X138.603Y-553.078
X138.716Y-553.192
X138.829Y-553.304
X138.985Y-553.374
X139.158
X139.33
X139.486Y-553.304
X139.599Y-553.192
X139.712Y-553.078
X139.782Y-552.922
Y-552.75
Y-552.578
X139.712Y-552.422
X139.599Y-552.309
X139.486Y-552.196
X139.33Y-552.126
X139.158
X138.985
X138.829Y-552.196
X138.716Y-552.309
X138.603Y-552.422
X138.533Y-552.578
Y-552.75
S0
X119.166Y-530.12
S200
Y-529.948F1000
X119.096Y-529.792
X118.983Y-529.679
X118.87Y-529.566
X118.714Y-529.496
X118.542
X118.37
X118.213Y-529.566
X118.1Y-529.679
X117.988Y-529.792
X117.918Y-529.948
Y-530.12
Y-530.293
X117.988Y-530.449
X118.1Y-530.562
X118.213Y-530.675
X118.37Y-530.744
X118.542
X118.714
X118.87Y-530.675
X118.983Y-530.562
X119.096Y-530.449
X119.166Y-530.293
Y-530.12
S0
X109.101Y-520.054
S200
Y-519.882F1000
X109.031Y-519.726
X108.918Y-519.613
X108.805Y-519.5
X108.649Y-519.43
X108.476
X108.304
X108.148Y-519.5
X108.035Y-519.613
X107.922Y-519.726
X107.852Y-519.882
Y-520.054
Y-520.227
X107.922Y-520.383
X108.035Y-520.496
X108.148Y-520.609
X108.304Y-520.679
X108.476
X108.649
X108.805Y-520.609
X108.918Y-520.496
X109.031Y-520.383
X109.101Y-520.227
Y-520.054
S0
X126.283Y-531.531
S200
Y-531.358F1000
X126.214Y-531.202
X126.101Y-531.089
X125.988Y-530.976
X125.831Y-530.906
X125.659
X125.487
X125.331Y-530.976
X125.218Y-531.089
X125.105Y-531.202
X125.035Y-531.358
Y-531.531
Y-531.703
X125.105Y-531.859
X125.218Y-531.972
X125.331Y-532.085
X125.487Y-532.155
X125.659
X125.831
X125.988Y-532.085
X126.101Y-531.972
X126.214Y-531.859
X126.283Y-531.703
Y-531.531
S0
X149.656Y-531.938
S200
Y-532.111F1000
X149.726Y-532.267
X149.839Y-532.38
X149.952Y-532.493
X150.108Y-532.563
X150.28
X150.453
X150.609Y-532.493
X150.722Y-532.38
X150.835Y-532.267
X150.905Y-532.111
Y-531.938
Y-531.766
X150.835Y-531.61
X150.722Y-531.497
X150.609Y-531.384
X150.453Y-531.314
X150.28
X150.108
X149.952Y-531.384
X149.839Y-531.497
X149.726Y-531.61
X149.656Y-531.766
Y-531.938
S0
X144.524Y-509.308
S200
Y-509.136F1000
X144.454Y-508.98
X144.341Y-508.867
X144.228Y-508.754
X144.072Y-508.684
X143.9
X143.727
X143.571Y-508.754
X143.458Y-508.867
X143.345Y-508.98
X143.276Y-509.136
Y-509.308
Y-509.481
X143.345Y-509.637
X143.458Y-509.75
X143.571Y-509.863
X143.727Y-509.933
X143.9
X144.072
X144.228Y-509.863
X144.341Y-509.75
X144.454Y-509.637
X144.524Y-509.481
Y-509.308
S0
X173.957Y-556.239
S200
Y-556.412F1000
X174.027Y-556.568
X174.14Y-556.681
X174.253Y-556.794
X174.409Y-556.863
X174.581
X174.754
X174.91Y-556.794
X175.023Y-556.681
X175.136Y-556.568
X175.206Y-556.412
Y-556.239
Y-556.067
X175.136Y-555.911
X175.023Y-555.798
X174.91Y-555.685
X174.754Y-555.615
X174.581
X174.409
X174.253Y-555.685
X174.14Y-555.798
X174.027Y-555.911
X173.957Y-556.067
Y-556.239
S0
X158.548Y-588.861
S200
X158.841Y-588.833F1000
X159.133Y-588.796
X159.423Y-588.752
X159.715Y-588.695
X160.006Y-588.631
X160.294Y-588.56
X160.974Y-588.357
X161.016Y-588.342
X161.057Y-588.328
X161.099Y-588.314
X161.34Y-588.226
X161.578Y-588.131
X161.814Y-588.029
X162.067Y-587.914
X162.316Y-587.791
X162.56Y-587.658
X163.207Y-587.301
X163.808Y-586.872
X164.354Y-586.381
X164.9Y-585.89
X165.39Y-585.337
X165.814Y-584.732
X166.232Y-584.126
X166.589Y-583.482
X166.88Y-582.81
X167.171Y-582.137
X167.397Y-581.436
X167.552Y-580.717
X167.588Y-580.543
X167.623Y-580.371
X167.658Y-580.197
X167.674Y-580.106
X167.681Y-580.013
X167.677Y-579.92
X167.617Y-577.79
X167.578Y-577.659
X167.561Y-577.528
X167.544Y-577.397
X167.549Y-577.266
X167.576Y-575.135
X167.646Y-570.768
X167.65Y-570.271
X167.977Y-570.113
X168.3Y-569.948
X168.619Y-569.775
X169.139Y-569.492
X169.647Y-569.19
X170.142Y-568.87
X170.637Y-568.55
X171.119Y-568.213
X171.586Y-567.858
X172.054Y-567.503
X172.508Y-567.131
X172.948Y-566.743
X173.387Y-566.356
X173.812Y-565.952
X174.22Y-565.532
X174.629Y-565.113
X175.023Y-564.679
X175.399Y-564.23
X175.776Y-563.781
X176.136Y-563.318
X176.479Y-562.841
X176.822Y-562.364
X177.148Y-561.874
X177.455Y-561.371
X177.763Y-560.868
X178.052Y-560.353
X178.322Y-559.826
X178.33Y-559.807
X178.596Y-559.293
X178.841Y-558.77
X179.064Y-558.236
X179.206Y-557.881
X179.347Y-557.523
X179.486Y-557.166
X179.83Y-556.146
X179.944Y-555.751
X180.056Y-555.355
X180.166Y-554.959
X180.261Y-554.582
X180.348Y-554.203
X180.427Y-553.822
X180.505Y-553.437
X180.574Y-553.05
X180.634Y-552.662
X180.775Y-551.564
X180.853Y-550.767
X180.895Y-549.967
X180.9Y-549.166
Y-549.08
X180.869Y-547.947
X180.847Y-547.525
X180.816Y-547.103
X180.775Y-546.682
X180.634Y-545.58
X180.574Y-545.193
X180.505Y-544.807
X180.427Y-544.424
X180.343Y-544.044
X180.256Y-543.665
X180.166Y-543.287
X179.973Y-542.541
X179.746Y-541.805
X179.486Y-541.08
X179.353Y-540.719
X179.213Y-540.361
X179.064Y-540.006
X178.987Y-539.824
X178.907Y-539.643
X178.826Y-539.463
X178.814Y-539.432
X178.588Y-538.947
X178.494Y-538.781
X178.408Y-538.61
X178.33Y-538.435
X178.322Y-538.416
X178.076Y-537.943
X177.806Y-537.447
X177.518Y-536.961
X177.214Y-536.485
X176.91Y-536.01
X176.589Y-535.545
X176.252Y-535.092
X176.209Y-535.033
X175.979Y-534.734
X175.745Y-534.437
X175.509Y-534.142
X174.818Y-533.346
X174.552Y-533.052
X174.278Y-532.766
X173.998Y-532.486
X173.619Y-532.119
X173.009Y-531.536
X172.368Y-530.987
X171.7Y-530.474
X171.032Y-529.961
X170.336Y-529.484
X169.615Y-529.045
X169.556Y-529.006
X168.634Y-528.474
X168.458Y-528.38
X168.281Y-528.288
X168.103Y-528.197
X168.084Y-528.189
X167.607Y-527.951
X167.572Y-527.932
X167.087Y-527.705
X167.056Y-527.693
X166.876Y-527.612
X166.695Y-527.533
X166.513Y-527.455
X166.158Y-527.306
X165.8Y-527.165
X165.439Y-527.033
X164.416Y-526.689
X164.023Y-526.575
X163.63Y-526.463
X163.236Y-526.353
X162.173Y-526.107
X161.401Y-525.951
X160.621Y-525.831
X159.837Y-525.748
X159.44Y-525.708
X159.041Y-525.676
X158.642Y-525.654
X158.564Y-525.65
X157.435Y-525.623
X157.365
X156.232Y-525.65
X156.154Y-525.654
X155.755Y-525.676
X155.356Y-525.708
X154.959Y-525.748
X153.857Y-525.889
X153.472Y-525.952
X153.088Y-526.02
X152.705Y-526.092
X152.323Y-526.171
X151.942Y-526.258
X151.564Y-526.353
X150.818Y-526.546
X150.082Y-526.773
X149.357Y-527.033
X148.996Y-527.166
X148.638Y-527.306
X148.283Y-527.455
X148.101Y-527.533
X147.92Y-527.612
X147.74Y-527.693
X147.708Y-527.705
X147.224Y-527.932
X147.057Y-528.025
X146.887Y-528.111
X146.712Y-528.189
X146.693Y-528.197
X146.515Y-528.288
X146.338Y-528.38
X146.162Y-528.474
X145.24Y-529.006
X144.593Y-529.399
X143.966Y-529.823
X143.361Y-530.275
X142.755Y-530.727
X142.171Y-531.208
X141.611Y-531.717
X141.479Y-531.849
X141.342Y-531.977
X141.201Y-532.099
X141.177Y-532.119
X140.433Y-532.829
X139.737Y-533.586
X139.093Y-534.385
X138.449Y-535.184
X137.857Y-536.026
X137.322Y-536.904
X137.283Y-536.963
X136.751Y-537.885
X136.657Y-538.061
X136.565Y-538.238
X136.474Y-538.416
X136.466Y-538.435
X136.2Y-538.949
X135.955Y-539.472
X135.732Y-540.006
X135.583Y-540.361
X135.442Y-540.719
X135.31Y-541.08
X134.966Y-542.103
X134.846Y-542.496
X134.734Y-542.89
X134.63Y-543.287
X134.54Y-543.665
X134.453Y-544.044
X134.369Y-544.424
X134.173Y-545.506
X134.056Y-546.292
X133.975Y-547.083
X133.931Y-547.877
X133.927Y-547.955
X133.9Y-549.088
Y-549.158
X133.927Y-550.291
X133.931Y-550.369
X134.017Y-551.486
X134.061Y-551.904
X134.113Y-552.321
X134.173Y-552.736
X134.369Y-553.822
X134.448Y-554.203
X134.535Y-554.582
X134.63Y-554.959
X134.744Y-555.355
X134.856Y-555.749
X134.966Y-556.146
X135.31Y-557.166
X135.449Y-557.524
X135.589Y-557.879
X135.732Y-558.236
X135.81Y-558.418
X135.889Y-558.599
X135.97Y-558.779
X135.982Y-558.81
X136.208Y-559.295
X136.302Y-559.461
X136.388Y-559.632
X136.466Y-559.807
X136.474Y-559.826
X136.799Y-560.458
X137.151Y-561.075
X137.53Y-561.674
X137.909Y-562.273
X138.315Y-562.854
X138.746Y-563.416
X139.176Y-563.977
X139.632Y-564.52
X140.112Y-565.041
X140.592Y-565.563
X141.096Y-566.063
X141.622Y-566.541
X142.419Y-567.232
X142.714Y-567.468
X143.011Y-567.701
X143.31Y-567.932
X143.769Y-568.274
X144.239Y-568.601
X144.72Y-568.912
X145.498Y-569.412
X146.306Y-569.865
X147.138Y-570.268
X147.146Y-571.271
X147.157Y-572.266
X147.169Y-573.269
X147.376Y-580.693
X147.379Y-580.835
X147.402Y-580.976
X147.443Y-581.111
X147.65Y-581.854
X147.935Y-582.571
X148.292Y-583.25
X148.648Y-583.929
X149.077Y-584.57
X149.572Y-585.162
X149.779Y-585.409
X149.999Y-585.645
X150.232Y-585.869
X150.44Y-586.073
X150.655Y-586.27
X150.876Y-586.459
X151.458Y-586.908
X151.709Y-587.082
X151.964Y-587.249
X152.224Y-587.408
X152.486Y-587.561
X152.753Y-587.704
X153.025Y-587.838
X153.262Y-587.944
X153.501Y-588.048
X153.74Y-588.15
X154.015Y-588.257
X154.294Y-588.353
X154.576Y-588.439
X154.832Y-588.507
X155.069Y-588.57
X155.326Y-588.639
X155.576Y-588.693
X155.827Y-588.74
X156.08Y-588.779
X156.353Y-588.817
X156.628Y-588.847
X156.904Y-588.869
X157.177Y-588.889
X157.45Y-588.898
X157.724Y-588.896
X157.841
X158.548Y-588.861
S0
X172.236Y-538.791
S200
Y-538.963F1000
X172.306Y-539.119
X172.419Y-539.232
X172.532Y-539.345
X172.688Y-539.415
X172.86
X173.033
X173.189Y-539.345
X173.302Y-539.232
X173.415Y-539.119
X173.485Y-538.963
Y-538.791
Y-538.618
X173.415Y-538.462
X173.302Y-538.349
X173.189Y-538.236
X173.033Y-538.166
X172.86
X172.688
X172.532Y-538.236
X172.419Y-538.349
X172.306Y-538.462
X172.236Y-538.618
Y-538.791
S0
X139.432Y-526.085
S200
Y-525.912F1000
X139.362Y-525.756
X139.249Y-525.643
X139.136Y-525.53
X138.98Y-525.46
X138.808
X138.635
X138.479Y-525.53
X138.366Y-525.643
X138.253Y-525.756
X138.183Y-525.912
Y-526.085
Y-526.257
X138.253Y-526.413
X138.366Y-526.526
X138.479Y-526.639
X138.635Y-526.709
X138.808
X138.98
X139.136Y-526.639
X139.249Y-526.526
X139.362Y-526.413
X139.432Y-526.257
Y-526.085
S0
X143.626Y-535.974
S200
Y-536.146F1000
X143.696Y-536.302
X143.809Y-536.415
X143.922Y-536.528
X144.078Y-536.598
X144.25
X144.422
X144.579Y-536.528
X144.692Y-536.415
X144.804Y-536.302
X144.874Y-536.146
Y-535.974
Y-535.801
X144.804Y-535.645
X144.692Y-535.532
X144.579Y-535.419
X144.422Y-535.349
X144.25
X144.078
X143.922Y-535.419
X143.809Y-535.532
X143.696Y-535.645
X143.626Y-535.801
Y-535.974
S0
X143.467Y-520.054
S200
Y-519.882F1000
X143.397Y-519.726
X143.284Y-519.613
X143.171Y-519.5
X143.015Y-519.43
X142.843
X142.671
X142.515Y-519.5
X142.402Y-519.613
X142.289Y-519.726
X142.219Y-519.882
Y-520.054
Y-520.227
X142.289Y-520.383
X142.402Y-520.496
X142.515Y-520.609
X142.671Y-520.679
X142.843
X143.015
X143.171Y-520.609
X143.284Y-520.496
X143.397Y-520.383
X143.467Y-520.227
Y-520.054
S0
X113.136Y-526.085
S200
Y-525.912F1000
X113.066Y-525.756
X112.953Y-525.643
X112.84Y-525.53
X112.684Y-525.46
X112.512
X112.339
X112.183Y-525.53
X112.07Y-525.643
X111.957Y-525.756
X111.887Y-525.912
Y-526.085
Y-526.257
X111.957Y-526.413
X112.07Y-526.526
X112.183Y-526.639
X112.339Y-526.709
X112.512
X112.684
X112.84Y-526.639
X112.953Y-526.526
X113.066Y-526.413
X113.136Y-526.257
Y-526.085
S0
X155.347Y-577.773
S200
Y-578.049F1000
X155.403Y-578.311
X155.504Y-578.55
X155.605Y-578.789
X155.751Y-579.005
X155.932Y-579.185
X156.113Y-579.366
X156.328Y-579.513
X156.567Y-579.614
X156.806Y-579.715
X157.069Y-579.771
X157.345
X157.62
X157.883Y-579.715
X158.122Y-579.614
X158.361Y-579.513
X158.576Y-579.366
X158.757Y-579.185
X158.938Y-579.005
X159.084Y-578.789
X159.185Y-578.55
X159.286Y-578.311
X159.342Y-578.049
Y-577.773
Y-577.497
X159.286Y-577.234
X159.185Y-576.995
X159.084Y-576.756
X158.938Y-576.541
X158.757Y-576.36
X158.576Y-576.179
X158.361Y-576.033
X158.122Y-575.932
X157.883Y-575.831
X157.62Y-575.775
X157.345
X157.069
X156.806Y-575.831
X156.567Y-575.932
X156.328Y-576.033
X156.113Y-576.179
X155.932Y-576.36
X155.751Y-576.541
X155.605Y-576.756
X155.504Y-576.995
X155.403Y-577.234
X155.347Y-577.497
Y-577.773
S0
X175.014Y-552.75
S200
Y-552.922F1000
X175.084Y-553.078
X175.197Y-553.192
X175.31Y-553.304
X175.466Y-553.374
X175.638
X175.811
X175.967Y-553.304
X176.08Y-553.192
X176.193Y-553.078
X176.262Y-552.922
Y-552.75
Y-552.578
X176.193Y-552.422
X176.08Y-552.309
X175.967Y-552.196
X175.811Y-552.126
X175.638
X175.466
X175.31Y-552.196
X175.197Y-552.309
X175.084Y-552.422
X175.014Y-552.578
Y-552.75
S0
X144.524Y-516.565
S200
Y-516.393F1000
X144.454Y-516.237
X144.341Y-516.124
X144.228Y-516.011
X144.072Y-515.941
X143.9
X143.727
X143.571Y-516.011
X143.458Y-516.124
X143.345Y-516.237
X143.276Y-516.393
Y-516.565
Y-516.738
X143.345Y-516.894
X143.458Y-517.007
X143.571Y-517.12
X143.727Y-517.19
X143.9
X144.072
X144.228Y-517.12
X144.341Y-517.007
X144.454Y-516.894
X144.524Y-516.738
Y-516.565
S0
X139.59Y-542.004
S200
Y-542.176F1000
X139.66Y-542.333
X139.773Y-542.445
X139.886Y-542.558
X140.042Y-542.628
X140.215
X140.387
X140.543Y-542.558
X140.656Y-542.445
X140.769Y-542.333
X140.839Y-542.176
Y-542.004
Y-541.832
X140.769Y-541.676
X140.656Y-541.563
X140.543Y-541.45
X140.387Y-541.38
X140.215
X140.042
X139.886Y-541.45
X139.773Y-541.563
X139.66Y-541.676
X139.59Y-541.832
Y-542.004
S0
X144.748Y-549.121
S200
Y-549.995F1000
X144.837Y-550.847
X145.005Y-551.671
X145.174Y-552.494
X145.422Y-553.289
X145.742Y-554.045
X146.063Y-554.802
X146.454Y-555.521
X146.909Y-556.194
X147.363Y-556.867
X147.881Y-557.494
X148.454Y-558.066
X149.026Y-558.639
X149.653Y-559.156
X150.326Y-559.611
X150.999Y-560.066
X151.718Y-560.457
X152.475Y-560.777
X153.231Y-561.097
X154.026Y-561.346
X154.849Y-561.514
X155.673Y-561.683
X156.525Y-561.771
X157.399
X158.272
X159.124Y-561.683
X159.948Y-561.514
X160.771Y-561.346
X161.566Y-561.097
X162.322Y-560.777
X163.079Y-560.457
X163.798Y-560.066
X164.471Y-559.611
X165.144Y-559.156
X165.771Y-558.639
X166.343Y-558.066
X166.916Y-557.494
X167.433Y-556.867
X167.888Y-556.194
X168.343Y-555.521
X168.734Y-554.802
X169.054Y-554.045
X169.374Y-553.289
X169.623Y-552.494
X169.791Y-551.671
X169.96Y-550.847
X170.048Y-549.995
Y-549.121
Y-548.248
X169.96Y-547.395
X169.791Y-546.572
X169.623Y-545.748
X169.374Y-544.954
X169.054Y-544.197
X168.734Y-543.441
X168.343Y-542.722
X167.888Y-542.049
X167.433Y-541.376
X166.916Y-540.749
X166.343Y-540.176
X165.771Y-539.604
X165.144Y-539.086
X164.471Y-538.632
X163.798Y-538.177
X163.079Y-537.786
X162.322Y-537.465
X161.566Y-537.145
X160.771Y-536.897
X159.948Y-536.728
X159.124Y-536.56
X158.272Y-536.471
X157.399
X156.525
X155.673Y-536.56
X154.849Y-536.728
X154.026Y-536.897
X153.231Y-537.145
X152.475Y-537.465
X151.718Y-537.786
X150.999Y-538.177
X150.326Y-538.632
X149.653Y-539.086
X149.026Y-539.604
X148.454Y-540.176
X147.881Y-540.749
X147.363Y-541.376
X146.909Y-542.049
X146.454Y-542.722
X146.063Y-543.441
X145.742Y-544.197
X145.422Y-544.954
X145.174Y-545.748
X145.005Y-546.572
X144.837Y-547.395
X144.748Y-548.248
Y-549.121
S0
X146.443Y-533.659
S200
Y-533.832F1000
X146.513Y-533.988
X146.625Y-534.101
X146.738Y-534.214
X146.895Y-534.284
X147.067
X147.239
X147.395Y-534.214
X147.508Y-534.101
X147.621Y-533.988
X147.691Y-533.832
Y-533.659
Y-533.487
X147.621Y-533.331
X147.508Y-533.218
X147.395Y-533.105
X147.239Y-533.035
X147.067
X146.895
X146.738Y-533.105
X146.625Y-533.218
X146.513Y-533.331
X146.443Y-533.487
Y-533.659
S0
X143.467Y-505.819
S200
Y-505.647F1000
X143.397Y-505.491
X143.284Y-505.378
X143.171Y-505.265
X143.015Y-505.195
X142.843
X142.671
X142.515Y-505.265
X142.402Y-505.378
X142.289Y-505.491
X142.219Y-505.647
Y-505.819
Y-505.992
X142.289Y-506.148
X142.402Y-506.261
X142.515Y-506.374
X142.671Y-506.444
X142.843
X143.015
X143.171Y-506.374
X143.284Y-506.261
X143.397Y-506.148
X143.467Y-505.992
Y-505.819
S0
X153.145Y-530.881
S200
Y-531.054F1000
X153.215Y-531.21
X153.328Y-531.323
X153.441Y-531.436
X153.597Y-531.506
X153.77
X153.942
X154.098Y-531.436
X154.211Y-531.323
X154.324Y-531.21
X154.394Y-531.054
Y-530.881
Y-530.709
X154.324Y-530.553
X154.211Y-530.44
X154.098Y-530.327
X153.942Y-530.257
X153.77
X153.597
X153.441Y-530.327
X153.328Y-530.44
X153.215Y-530.553
X153.145Y-530.709
Y-530.881
S0
X127.711Y-484.286
S200
Y-484.01F1000
X127.655Y-483.747
X127.554Y-483.508
X127.453Y-483.269
X127.306Y-483.054
X127.126Y-482.873
X126.945Y-482.692
X126.73Y-482.546
X126.491Y-482.445
X126.252Y-482.344
X125.989Y-482.288
X125.713
X125.437
X125.174Y-482.344
X124.935Y-482.445
X124.696Y-482.546
X124.481Y-482.692
X124.3Y-482.873
X124.12Y-483.054
X123.973Y-483.269
X123.872Y-483.508
X123.771Y-483.747
X123.715Y-484.01
Y-484.286
Y-484.561
X123.771Y-484.824
X123.872Y-485.063
X123.973Y-485.302
X124.12Y-485.517
X124.3Y-485.698
X124.481Y-485.879
X124.696Y-486.025
X124.935Y-486.126
X125.174Y-486.227
X125.437Y-486.283
X125.713
X125.989
X126.252Y-486.227
X126.491Y-486.126
X126.73Y-486.025
X126.945Y-485.879
X127.126Y-485.698
X127.306Y-485.517
X127.453Y-485.302
X127.554Y-485.063
X127.655Y-484.824
X127.711Y-484.561
Y-484.286
S0
X163.891Y-531.938
S200
Y-532.111F1000
X163.961Y-532.267
X164.074Y-532.38
X164.187Y-532.493
X164.343Y-532.563
X164.516
X164.688
X164.844Y-532.493
X164.957Y-532.38
X165.07Y-532.267
X165.14Y-532.111
Y-531.938
Y-531.766
X165.07Y-531.61
X164.957Y-531.497
X164.844Y-531.384
X164.688Y-531.314
X164.516
X164.343
X164.187Y-531.384
X164.074Y-531.497
X163.961Y-531.61
X163.891Y-531.766
Y-531.938
S0
X133.402Y-530.12
S200
Y-529.948F1000
X133.332Y-529.792
X133.219Y-529.679
X133.106Y-529.566
X132.95Y-529.496
X132.777
X132.605
X132.449Y-529.566
X132.336Y-529.679
X132.223Y-529.792
X132.153Y-529.948
Y-530.12
Y-530.293
X132.223Y-530.449
X132.336Y-530.562
X132.449Y-530.675
X132.605Y-530.744
X132.777
X132.95
X133.106Y-530.675
X133.219Y-530.562
X133.332Y-530.449
X133.402Y-530.293
Y-530.12
S0
X136.615Y-528.399
S200
Y-528.227F1000
X136.545Y-528.071
X136.432Y-527.958
X136.319Y-527.845
X136.163Y-527.775
X135.991
X135.818
X135.662Y-527.845
X135.549Y-527.958
X135.436Y-528.071
X135.366Y-528.227
Y-528.399
Y-528.571
X135.436Y-528.728
X135.549Y-528.841
X135.662Y-528.953
X135.818Y-529.023
X135.991
X136.163
X136.319Y-528.953
X136.432Y-528.841
X136.545Y-528.728
X136.615Y-528.571
Y-528.399
S0
X144.878Y-512.936
S200
Y-512.764F1000
X144.808Y-512.608
X144.695Y-512.495
X144.582Y-512.382
X144.426Y-512.312
X144.253
X144.081
X143.925Y-512.382
X143.812Y-512.495
X143.699Y-512.608
X143.629Y-512.764
Y-512.936
Y-513.109
X143.699Y-513.265
X143.812Y-513.378
X143.925Y-513.491
X144.081Y-513.561
X144.253
X144.426
X144.582Y-513.491
X144.695Y-513.378
X144.808Y-513.265
X144.878Y-513.109
Y-512.936
S0
X139.59Y-556.239
S200
Y-556.412F1000
X139.66Y-556.568
X139.773Y-556.681
X139.886Y-556.794
X140.042Y-556.863
X140.215
X140.387
X140.543Y-556.794
X140.656Y-556.681
X140.769Y-556.568
X140.839Y-556.412
Y-556.239
Y-556.067
X140.769Y-555.911
X140.656Y-555.798
X140.543Y-555.685
X140.387Y-555.615
X140.215
X140.042
X139.886Y-555.685
X139.773Y-555.798
X139.66Y-555.911
X139.59Y-556.067
Y-556.239
S0
X115.953Y-528.399
S200
Y-528.227F1000
X115.883Y-528.071
X115.77Y-527.958
X115.657Y-527.845
X115.501Y-527.775
X115.329
X115.156
X115Y-527.845
X114.887Y-527.958
X114.774Y-528.071
X114.704Y-528.227
Y-528.399
Y-528.571
X114.774Y-528.728
X114.887Y-528.841
X115Y-528.953
X115.156Y-529.023
X115.329
X115.501
X115.657Y-528.953
X115.77Y-528.841
X115.883Y-528.728
X115.953Y-528.571
Y-528.399
S0
X109.101Y-505.819
S200
Y-505.647F1000
X109.031Y-505.491
X108.918Y-505.378
X108.805Y-505.265
X108.649Y-505.195
X108.476
X108.304
X108.148Y-505.265
X108.035Y-505.378
X107.922Y-505.491
X107.852Y-505.647
Y-505.819
Y-505.992
X107.922Y-506.148
X108.035Y-506.261
X108.148Y-506.374
X108.304Y-506.444
X108.476
X108.649
X108.805Y-506.374
X108.918Y-506.261
X109.031Y-506.148
X109.101Y-505.992
Y-505.819
S0
X108.044Y-509.308
S200
Y-509.136F1000
X107.974Y-508.98
X107.861Y-508.867
X107.748Y-508.754
X107.592Y-508.684
X107.419
X107.247
X107.091Y-508.754
X106.978Y-508.867
X106.865Y-508.98
X106.795Y-509.136
Y-509.308
Y-509.481
X106.865Y-509.637
X106.978Y-509.75
X107.091Y-509.863
X107.247Y-509.933
X107.419
X107.592
X107.748Y-509.863
X107.861Y-509.75
X107.974Y-509.637
X108.044Y-509.481
Y-509.308
S0
X138.533Y-545.493
S200
Y-545.666F1000
X138.603Y-545.822
X138.716Y-545.935
X138.829Y-546.048
X138.985Y-546.117
X139.158
X139.33
X139.486Y-546.048
X139.599Y-545.935
X139.712Y-545.822
X139.782Y-545.666
Y-545.493
Y-545.321
X139.712Y-545.165
X139.599Y-545.052
X139.486Y-544.939
X139.33Y-544.869
X139.158
X138.985
X138.829Y-544.939
X138.716Y-545.052
X138.603Y-545.165
X138.533Y-545.321
Y-545.493
S0
M5 S0
G0 X200 Y200 Z0 (move back to origin)
dab55
(Douglas Brown)
May 9, 2022, 8:51am
#6
Sorry berainlb I missed the question in your response. The SVG file came from AirTag Mold | Template for lasercutting by grumpy_scrambler - Thingiverse
The original file had a 1 cut layer and 1 engrave layer. I used Inkscape to remove the engrave layer.
The .lbrn file you attached has 2 layers: one offset fill layer and one line layer that seems to match the photos and the g-code output. Can you confirm you’re only running the line layer for your tests?
The preview you attached is showing both so a little confused there.
Assuming that you’re only outputting the line layer I don’t see anything fundamentally wrong in the g-code or .lbrn file. LightBurn is commanding the laser to do the right thing. For some reason the laser is not complying.
I think what may be going on is that your machine is losing steps somewhere. Looks to me like a loose belt situation or possibly a situation where you’re driving the motors faster than they can go. First do a mechanical review of your system as it’s best to address any physical concerns before trying to address this with settings.
When you run this in LightBurn do you hear a buzzing or straining noise from the motors? If not, more likely an issue with belt tension or possibly belt alignment. Belts should be taught with no slack but not stretched.
I suspect the reason why this is happening in LightBurn and not LaserGRBL Is because LightBurn is using rapid moves between individual shapes. The individual shapes are being burned at your cut speeds but rapid moves will go at the max travel speed as configured in GRBL. That is set to 10,000 mm/min ($110, $111) for you currently on both axes. It’s possible that is fast enough to expose any mechanical issues on your system. LaserGRBL seems to be using G1 and cut speeds for all movements. Did the burn in LaserGRBL take longer than LightBurn?
dab55
(Douglas Brown)
May 10, 2022, 12:54am
#8
I can confirm that I am only burning the line layer from the SVG as I removed the offset layer before sending the job to the laser.
I have already checked belt tension and there is no unusual sounds from the steppers while in operation.
I will try lowering the fast move speed.
The order of the burn is totally different i Lightburn to LaserGRBL .
This is not the only job that I experience this trouble with. Most multi layer jobs have a registration problem with Lightburn resulting in the different layers being offset.
LaserGRBL doesn’t give you many options to tweak laser path but LightBurn gives you a number of tools in the cut settings and optimization settings. However, it’s not so much the optimization that’s causing the problem in this case if my hypothesis holds up.
If you load the LightBurn gcode in LaserGRBL you can see that the planned shapes are as you would expect. In looking at the g-code you can see that LightBurn is using G0 rapid moves to go between shapes. An issue here would explain why the individual shapes of the LightBurn sample look okay while the spaces between shapes is skewed.
I’m not aware of your specific setup but 10,000 mm/min may very well be faster than your machine is capable of going so worth exploring.
That wouldn’t surprise me. Basically anything that uses rapid moves would be a problem. In fact, even the start point of jobs may not be accurate as the laser head moves to the starting position.
dab55
(Douglas Brown)
May 10, 2022, 3:04am
#10
I have checked all belts and rollers, turned of “Fast White Space” and re run the job.
Results are still the same, it burns the outline of the front then the stitch holes and front window, finishing with the back of the item.
The front and back of the item are positioned accuratly however, the stitch holes and front window are not as the laser is not moving the correct Y position before burning each of these.
I have attached a link to a video of the burn.Burn Video https://drive.google.com/file/d/1zV6P77MEkdJ_4Z2ME1KKFjUtY3E5ggrl/view?usp=sharing
I responed on private message but let me repeat here so that others can benefit.
You cannot change rapid move speed with “fast white space”.
Based on the video I’m fairly certain your motors are skipping based on the sound. Not certain but they sound strained.
You need to change the settings for $110 and $111. Do this either in Machine Settings or in Console. For example, you wanted to try setting to 5000 mm/min:
$110=5000
$111=5000
I suggest you start out low and test. If it works, you can incrementally increase the value until you notice skipping and then dial it back.
dab55
(Douglas Brown)
May 10, 2022, 5:58am
#12
Thank you berainlb, I lowered these settings to 2000 and the job completes correctly.
I have avoinded tweeking the setiings in the Output Settings section of Machine Settings as Lightburn issues a warning about changing these setting
I have attached an image showing the output settings I have. could you please any other recomended changes.
Once again thank you. I have a smile from ear to ear.
Great news. Glad that worked.
Was this the upper limit of speed before your steppers would skip? This is a pretty low value. If not, I’d encourage you to experiment to identify that upper limit so you can take full advantage of your hardware.
Could he do a test card that starts at a low speed and incrementally speeds up until things go screwy?
dab55
(Douglas Brown)
May 10, 2022, 12:14pm
#15
I did some more testing and 3500 seems to be the limit. I have 17hs4023 steppers brand name Usongshine.
I have fought with this machine for over a year trying to get it setup to use Lightburn and now it is working perfectly.
Oh wow. That must be an immense sense of relief.
I think you were a bit lucky in this case that LaserGRBL had different results than LightBurn. It provides a relatively easy comparative reference.
Now you can just enjoy the process rather than fighting the machine.
Try this:
Group EACH of the parts as one…in your case, you will have 2 groups.
Then go into DEVICES → OPTIMIZATIONS and then pick REMOVE and then pick “ORDER BY GROUP”. Make sure your CUT layer is the last layer you use. Also pick “Cut Inner shapes first” and also “Reduce Travel Moves”
With a properly tuned machine, none of these settings should affect whether the output works or not, just the order in which things are done.
dab55
(Douglas Brown)
May 11, 2022, 2:21am
#19
Thank you Keith for you advise, I am like a sponge sucking up all the knowledge I can find when it comes to laser engraving and cutting.
dab55
(Douglas Brown)
May 11, 2022, 10:13am
#20
one last question if I may. Are the $110 and $111 settings limitted by the stepper motor or THE STEPPER motor driver ?
