Problem with one of Axis
@killrob I tried, but result is the same like before, on engraving still have to push test button for turn on laser, yes it have 3 pin cable and all is connected well by colors,
What i supposed to check next?
Well, i have to make a test with my Mana cause the last time i used it was connected to a 5.5W module, now i’m at work at 5.30 Pm, Rome time, i’m back home and can try, please be patient
@killrob sure man, text my then you can
Hi, thank you guys, this thread is really useful!
I’m quite an idiot, i forget to ask you 1 important thing, you power supply how many Ampere has in out? Cause Eleksmaker tell that MUST be used a PS with at least 5A but better more infact my power supply is a 20A in output
I think he has a lot power because then charger is pluged in he turns on
@killrob 2021 m. lapkričio 15 d. - YouTube
Then powerrl button turning on
You’re not using this one for the laser module right?
Yes im using it, some problems here?
@killrob ofc, with 12v, because he has a option which power wanna to use from 12 to 24
Ok i made the test and with my Mana V5.2 works like a charm.
So you have a PS with 12V 5A? cause A40630 needs 12V and the adapter transform it in 3.3V.
Other question, in the video i see you old MB that is not the Mana V5.2 but the Mana SE and with that i’m not sure will work.
Have you got some friend that can lend you a PS like this?
cause is the only thing that in your test was not changed.
I had the same problem with an Atomstack I bought. Laser would fire be X and Y were dead. I got new firmware from the vendor and it has been working fine ever since.
