I have done testing in increments of 100mm/s and 10% power increase from 300mm/s at 30% all the way to 2000mm/s at 200% override.
My motor does not slip the belt, my machine does not shake excessivly.
I will find itslimit, either mechanically or electronically and provide the results
I have not done a measurement of actual speed.
I will soon using the camera method of taking a video across a marked distance.
I’ll make 10cm long rectangles to engrave and watch that at every speed from 300 to 2000, to see what’s really happening.
. 1% overscan is too much and it actually makes 2000 take longer than say 1900 because the distance Is greater…
Overscan off makes my engraving incomplete at the edges.
My type 2 unbranded laser psu, has almost zero internet documentation that I can find, other than basic hook ups.
I’ll be adding additional grounding to it as well.
I am done messing with mks firmware. It is absolutely trash fire dumpster heap…
I will be upgrading to fluidnc, regardless of the major inconvenience of not having a screen mounted to my machine to run repeating batch jobs quickly in the short term.
Long term fix will be to use a secondary esp32 to act an an AP of its own wifi network, and then use that as intermediate connection between my Mks DLC32 and an android tablet that I have.
Something strange is going on and I will get to the bottom of it.
Untill I have a new list of findings, I’ll be off the webs asking questions… Quite frustrating, but I have to remember, my $1300 machine that’s 4’x4’ and 40 watts, is at least 5x cheaper than the cheapest one commercially available…
Ive probably burnt through that much value messing with this “prototype”.
And finally, the laser scene has blown up so much in the last few years, like 3d printing did a decade ago…
Maybe it’s time to rethink why I’m bothering…
