When I place a shape with Lightburn, I display the border.
If he lasers then totally wrong?
Set up and calibrated camera.
What am I doing wrong.
I have the Atom A10Pro
Wenn ich eine Form platziere mit Lightburn, lasse ich den Rahmen anzeigen.
Wenn er lasert dann total daneben?
Habe Kamera eingerichtet und Kalibriert.
Was mache ich falsch.
The first question I have is which coordinate system are you using?
When connected to your Atomstack A10 Pro in LightBurn please open the window and type the following:
$i
$G
and copy / paste the text from the console window into a reply here.
A work offset can create the condition where the framing does not match the location of the commanded work.
Hallo vielen Dank für deine Tipps. Ich habe den Fehler gefunden das war die Kamera!
Ich habe eine andere angeschlossen und funktioniert 100 mal besser musst du nur noch bei Kamerasteuerung den Versatz bisschen nachstellen und schon lasert er da wo ich möchte
Hello, thank you for your tips. I found the fault it was the camera!
I have connected another one and it works 100 times better, you only have to adjust the offset a bit when controlling the camera and it lasers where I want it
I have merged the threads where duplicate posts were made and deleted the duplicates. Please refrain from duplicating posts as it increases workload and confusion.
