I’m experiencing an issue now where the engraving cuts out at random times. The console says the stream is completed, but really its only 15% to 40% done. This is the first time I have done a graphic pattern at this size but previously I was able to dither etch simple gradients. The settings are the same so I so I am not sure what the issue is. below is the console dialog and attached is my file.
Please help. I have ruined a few expensive quartz tubes because of this. I have since switched back to laserweb just get this job done, but it does not have as many dither patterns available.
Waiting for connection…
Port opened, waiting for response.
Grbl 1.1f [’$’ for help]
[MSG:’$H’|’$X’ to unlock]
ok
[MSG:Caution: Unlocked]
ok
ok
ok
Starting stream
[MSG:Pgm End]
Stream completed in 0:15
Starting stream
[MSG:Pgm End]
Stream completed in 0:11
Starting stream
[MSG:Pgm End]
Stream completed in 0:13
Starting stream
[MSG:Pgm End]
Stream completed in 17:18
Starting stream
[MSG:Pgm End]
Stream completed in 17:16
Starting stream
[MSG:Pgm End]
Stream completed in 0:16
Starting stream
[MSG:Pgm End]
Stream completed in 0:22
Starting stream
[MSG:Pgm End]
Starting stream
Stream completed in 8:58
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ALARM:3
ok
ok
Starting stream
Stream completed in 0:01
ALARM:3
ok
ok
Starting stream
Stream completed in 23:42
ALARM:3
ok
oktest 1.lbrn (518.2 KB)
