If lightburn isn’t executing, then it isn’t going to interfere with the machines i/o ports.
It would be a disaster to modify a ‘standard’ USB port and make it unavailable to another program. I don’t run Lightburn as an Administrator, so I know it isn’t ‘modifying’ any of my com ports.
These controllers are ‘dumb as a rock’, so if it’s anything, it’s probably the controller dealing with the com port you are using.
It’s always much better to dump the USB and connect via Ethernet if at all possible.
Good luck on the upgrade…
I’ve seen so many ‘bricked’ devices, I don’t upgrade unless there is a specifically good reason.
If I connect via Ethernet, is that just connecting an Ethernet cable between the PC and Main Board, and setting the ports?
Or does the Main board need connecting into the router where the PC would be connected?
I’ve ready about Ethernet connections but none actually tell you this.
Yeah, thanks I have read this already, but it doesn’t actually tell me how to connect it up
I did install the USB driver from Rdworks also several time now…but it has never worked. The Thunderlaser version worked on my old controller but Rdworks it’s self has never connected
