Please forgive me if the answer to this question is completely obvious.
I’m considering building a 50W’ish CO2 laser. A question I have is about the controller and its role when using Lightburn.
For context I built a CNC router (PrintNC) using a control board from UCCNC operated by their excellent software running on a laptop. So adhoc control of the CNC router (jogging etc.) is done from via the software on the laptop. Feeds and speeds (similiar to power and speed on a laser) are typically set in the cut file but speed can be adjusted on the fly via the software.
I see that CO2 lasers (from K40 on up) have controls on the machine.
My question is if I can e to jog, home etc. the laser from Lightburn, what is the role of a controller interface like a Ruida has when paired up with Lightburn?
This is the Key distinction between GCode controllers and Ruida (DSP) controllers.
With a GCode controller the GCode generated dictates the path, speeds and laser output most of the time. There is a cornering algorithm but that’s the extent of that control.
The DSP controller handles data faster and provides more nuanced control over the motion planning.
I’m deliberately excluding discussion of the internal technical aspects of the controllers but from a user perspective, in very broad terms, DSP controllers are all offline controllers. They can run jobs without LightBurn on. Most g-code controllers are online controllers. They require LightBurn to be connected and streaming data to the controllers to run a job. Having said that, offline g-code controllers do exist.
