Rotary attachment inconsistencies
Hi all, Im new here!!!
I am running into an issue where “steps per rotation” need to be set every time. This is a number that I thought you set specifically for the motor and not for the work piece. Yesterday I had a SPR set at 13800 then today it required 10000 for the same work piece. all the other variables were correct. I’m so confused. What am I missing?
Are you using a chuck rotary, or roller rotary? Did you have “Enable Rotary” enabled one day, and disabled the next?
