Is there a way to see how long it took for a rotary job (for Galvo machines) to complete? Its only available on non-rotary jobs as far as I can tell.
jkwilborn
(Jack Wilborn)
February 7, 2023, 9:03pm
2
Preview doesn’t work?
Haven’t hooked up the rotary yet…
The preview shows the time (close enough for good) for my 110 lens but for some reason, the 175 lens is way off. I’ve fiddled with my settings and just timed it…
That got boring quickly so popped the question here.
see above (didnt hit reply )
jkwilborn
(Jack Wilborn)
February 7, 2023, 11:58pm
5
I’m confused about speeds also… Posted it in these posts…
I have my scan speeds set to around 300mm/s when testing the galvo when I assembled it yesterday.
I have bumped it up to 1500mm/s and it doesn’t look any faster. The preview is supposed to take 30 some seconds and takes 8 minutes…
I have looked for a limit value for X or Y but there doesn’t seem to be one…
Framing is set to 4000mm/s and I don’t think it’s running that fast either.
Any suggestions on how to speed up the scan…?
I have setup my laser for my 300x300mm coverage and have used the 2,000mm/s speeds…
I have two more lenses coming that are far shorter…
I’ve assumed the 2,000mm/s was being applied to the material … probably erroneously…
If I change the height of the galvo head, it will change how fast the surface speed is on the material.
If at the A height, it’s laying down 2000mm/s, it has to engraving faster at the B height with the same settings.
Is this adjustable based on lens size?
[scan-speed-adj…
Don’t know what to tell you…
system
(system)
Closed
March 9, 2023, 11:59pm
6
