Parra73
(Pär Mechau)
February 5, 2024, 6:35pm
1
Does LightBurn have any plans to fix it so you can select axis in the software so they work with Ruida controllers?
JohnJohn
(John Johnson)
February 5, 2024, 6:47pm
2
Several folks here use a rotary device with their Ruida (DSP) controlled laser engraver. There are some controller firmware limitations.
If you have the RDC6445S controller (NOT G) then this might just be your lucky day.
Here is my link to the Firmware for this controller
https://drive.google.com/drive/folders/1_LAxx9-GAc2S9mKJp4kja74dVDvk7eTV?usp=sharing
There are 2 Firmware versions - V26.01.13 and V26.01.16
.13 will run your rotary off the U Axis.
.16 will run your rotary off the Y Axis.
Firmware has to be upgraded through RDWorks
I have added a 3rd Axis driver to my machine and all rotary settings are set up on that U …
Parra73
(Pär Mechau)
February 5, 2024, 6:57pm
3
After 2 weeks of testing i finaly fixt it.
A have RDC6445S Firmware V35.01.08
But it would have been nice if it had worked in LightBurn so you could select and run the test in the program directly.
system
(system)
Closed
March 6, 2024, 6:58pm
4
