What rotary do you use and on which axes? Y, U?
This thread tells you how to set this up… you should not need to change controller setting values when you change to a rotary. If you have a problem in the setup, please sing out…
Does your machine have relay/switches to enable the rotary?
If the machine is setup properly it, pressing the test button in the setup should turn the chuck the complete rotation and back. If it’s a wheeled or roller rotary the drive wheel should rotate one complete turn and back.
Lets get this rotary configured correctly then we’ll move on…
