Yesterday ı make the factory reset for my 100w Model SL 1060 Laser
All settıngs gone. Any body got lbset file ?
Might try File → Load Prefs Backup
Otherwise you should email the vendor and see if they can bail you out while you wait for someone with a similar machine.
Always backup software/firmware or configuration data before you reset or modify any items.
You then have all the correct data to restore it to vendors settings. This can be done Edit → Machine Settings and using the appropriate button to save to file and so forth.
Good luck
