Ruida, settings differ on LB and controller when sent a job
The MaxPower settings are the values set directly on the console by poking the Power button, rather than in a job layer. Those apply when the machine is not running a job and you’re playing Etch-a-Sketch with the laser.
Also, the 5 mm/s layer speed is (probably) below the controller’s Start Speed, which is usually 10 mm/s (or so). In that situation, the controller unilaterally reduces the power to the layer’s Min setting while running the layer:
That’s almost certainly the setting for the jog arrow buttons:
  • Manual = moves a specific distance for each press
  • Continue = moves until button is released
There’s a Menu setting for the Manual step distance.
Or, hey, I’m about to learn something new today … :grin:
