I’m evaluating LB for a company that uses hardened environments, so most 3rd party software must be run in docker containers.
I got LB to open successfully in a slightly modified Ubuntu docker image, but I can’t get past the trial dialog. It claims the system time has been tampered with or that the trial period has ended.
I believe the trial license key can only ever be activated once for a given hardware profile. With the “tampering” of the environment through the container being recreated it’s likely just picking up on that.
It’s not clear to me whether or not you’d experience the same issue if you were using a persistent key. I’d suggest sending an email to support@lightburnsoftware.com with a link to this Topic and explaining some of your organization’s needs and they may be better help you walk through possible licensing options.
Same type of problem:
My computer is (still) under Ubuntu 18, so to be able to launch Lightburn 1.3 I configured an Ubuntu 22 (latest) docker container.
After some tweaks I now launch LightBurn correctly, but I must reenter the key at each launch.
What is weird is that the activation details on cryptlex are the same (only the update and sync times are changed) so it is still considered to be the same machine (in fact the same as the host computer, but with another hostname and the ‘container’ attribute set to ‘true’ on cryptlex).
So I suppose that some license-related information is not kept in a permanent/mounted directory (that is is stored in a temporary container directory instead of a permanent directory on the host computer).
Could you tell me where the activation information is stored, so that I make that place permanent?
Thanks in advance…
I’m surprised this works. When I experimented with this earlier I had the impression that there were further sub depenencies. Also, surprised that you didn’t get complaints of an older LD loading a newer GLIBC library.
But nice getting this to work. Could be helpful for others.
Have you tried a bootable ISO with the persistent filesystem enabled(a partition on the USB or HD having a label of “casper-rw”). Also need to boot with the word persistent (or persistence ) on the boot cmd line. That should keep anything LightBurn requires around on the persistent overlay filesystem.
All the license info is hidden in the ~/.config/Lightburn/prefs.ini
My problem with the use of docker came from not being able to resolve ‘~’ from the inside of the container.
I solved if by forcing my id into /etc/passwd and /etc/group during the container construction - not particularly clean but effective.
To sum up, for those that NEED to use docker, my solution is
A) Build a container with a dockerfile:
FROM ubuntu
RUN apt update
RUN apt install -y libusb-1.0-0
RUN apt install -y libpulse-dev
RUN apt install -y libgl1
RUN apt install -y build-essential libgl1-mesa-dev
RUN apt install -y libxkbcommon-x11-0
RUN apt install -y libxcb-image0
RUN apt install -y libxcb-keysyms1
RUN apt install -y libxcb-render-util0
RUN apt install -y libxcb-xinerama0
RUN apt install -y libxcb-icccm4
RUN apt install -y libxi6
RUN apt install -y libxinerama1
RUN apt install -y libxrender1
RUN apt install -y net-tools
RUN apt install -y iputils-ping
RUN echo “jbarbier:x:1000:1000:Jean Barbier,:/home/jbarbier:/bin/bash” > /etc/passwd
RUN echo “jbarbier:x:1000:” > /etc/group
are you saying that with that setup it will repeatedly launch with a working LightBurn once you input your LB license key the first time or does the LB license key have to be entered every launch of the docker image?
This setup works for me transparently, I don’t have to enter the license key at each launch.
In my case, the license key was already validated on this computer as I had run LB version 1.2 natively, but I guess that it should also work for a first time activation through the docker image.
The relevant factor is really to be able to run LB in the container with the right user_name/user_id AND to have correctly mapped the homedir to be able to find the prefs.ini at a permanent place (if you miss that step, a temporary prefs.ini will used - no license, but also, and it is a signal, no previously defined machine, etc)
I’ll have to try this on my dev laptop( 16GB RAM ) but older 18.04 version of Ubuntu to see how well it works since it could be a way to run with the more current version of Ubuntu OS and libs.
Thanks for taking the time to write out the steps and descriptions!
@jgbarbier I ran it as you posted it except for the userID/userName changes and it worked splendidly. Well done and it’s pretty cool to be able to run LightBurn on 22.04 code from a laptop still running 18.04.
I’ve not been able to get the camera working though but not a big problem right now.
the device just doesn’t show up in the Camera tab dropdown list. I’ve tried -v /dev/video0:/dev/video0 and I’ve tried --device=/dev/video0:/dev/video0. I also tried adding --privileged.
Do you mean with the host OS or outside of Lightburn within the docker container?
It works on the host OS with previous versions of LightBurn but since LightBurn 1.3.1 requires libm.so.6 I can’t test the latest version on the host OS. THIS is why running LightBurn through a Docker container which is running Ubuntu v22.04 is so handy.
./LightBurn: /lib/x86_64-linux-gnu/libm.so.6: version `GLIBC_2.29’ not found (required by ./LightBurn)
