Sad new user: can't get past "error:20 Unsupported or invalid g-code command found in block"
You have your laser configured as ilaser. Did you try the fix in post 20 of this Topic?
yes i did that. It was alredy on iLaserr device type
You do not want to be on iLaser device type. You want to be GRBL. Have you tried GRBL profile?
YES now it works, sorry my mistake. Tnx for helping me :smile:
Yeah. This worked for me too. YYAY
Bonjour,
comme beaucoup j’ai ce fameux problème de erreur G-CODE!
après avoir essayer tous ce qui est écrit dans vos réponse j’ai réuçi uniquement à découper un carré mais impossible de faire autre chose . Voici le code erreur affiché:
Démarrage de flux
Flux terminé en 0 :00
Démarrage de flux
Layer C00
error:20
Commande g-code non prise en charge ou non valide trouvée dans le bloc.
En ligne ou quasi en ligne 2 :
Travail interrompu
je vous met aussi une copie de mon fichier G-Code.
2021-12-23 error 20.txt (704 Bytes)
Merci à tous.
Looks like you have the rotary enabled. Disable the rotary in Laser Tools->Rotary Setup.
Layer C00
error:20
Travail interrompu
same error in lightburn 1.3.0
z axe inactive
Did you disable Rotary?
Please take a full screenshot of LightBurn with the design loaded and ready to burn.
Thank you so so much!! This mistake made me crazy.
I have a similar problem, this is the error:
Starting stream
Layer C00
error:20
Unsupported or invalid g-code command found in block.
On or near line 0:
error:20
On or near line 2:
Job halted
Stream completed in 0:00
ok
ok
ok
ok
I’m pasting the Gcode for reference.
Test1.txt (1,6 KB)
I’m using an iDraw 2.0 laser engraver (https://idrawpenplotter.com)
EDIT: I realised my firmware is not the latest (V2.08 instead of V2.09) but the firmware update provided by the laser manufacturer glitches and does not work.
Thanks to anyone who will be willing to help :pray:
@MArcoseb @nedim2501 I’d encourage you both to create new Topics for your specific issues. Your issues is likely different enough from the original that the same fix does not apply.
Please make sure to include as much detail about your situation as possible. That will help people understand what you’re facing.
thanks berainlb!
Thank you for this question and answer. Days Ive been fretting over this machine thinking Id have to buy a new one. I did try to use the roller thingybob last time I use it. Thank you again :hugs::+1:
Hi there,
Totally new and had no idea what I was getting into when I bought my FoxAlien Masuter Pro 4040. I’m getting this response in console:
Starting stream
error:20
On or near line 1:
[MSG:Pgm End]
On or near line 1:
ALARM:2
G-code motion target exceeds machine travel. Machine position safely retained. Alarm may be unlocked. (Right-click the ‘Devices’ button to reset the connection)
[MSG:Reset to continue]
Grbl 1.1h [‘$’ for help]
[MSG:‘$H’|‘$X’ to unlock]
[MSG:Caution: Unlocked]
ok
07.31.2025 error 20.gc (558.2 KB)
I hope i added the file right.
Some context, I am unable to move my X and Y axis. I used to, and completed a couple of jobs (laser and carving).
I had accidently entered $@ or $# command and it said ok, I didn’t know how to take it back. After that I’ve been having axis problems. Z axis works still.
