Safe Maximum PWM with CO2 Lasers
For a glass tube powered by a normal 'ole power supply, the reality is that your Laser PSU has a G (ground). It also has the 5V input that is essentially the power on signal to the LPSU. You have an IN that accepts either a “digital” PWM or an Analog signal that is used to trim the aforementioned 5V signal from 0 to 5v (which in turn regulates the LPSU’s current to the laser tube).
