The advantage of using the analog output over the PWM is you’re not requiring your laser PSU to translate the PWM into a 0 - 5v signal. That’s what the controller is doing. If you have a Laser PSU that accepts analog signaling, you should use it. That’s why It is recommended by Ruida.
