Hi.
Nothing wrong with it if You definitely need a window, but IMO in 99% of the cases, a camera will do just fine.
Especially with dual wavelength use (I have the same combo).
Often for a fraction of the price as well
I stopped looking for even a single wavelength window pretty quickly when I made my ATA style case for my xTool D1 Pro, so I can’t give You a definitive answer, but I doubt that such a safety window exists.
At least not in the “reasonable price” range.
If You mean solid colour, yes it will.
If it’s at all transparent, then the answer is maybe for without the glasses, yes with the glasses.
The forming method doesn’t matter.
It’s easy to rough-test any plastic sheet by lasering through it.
If a paper under the sheet shows any signs of charring, a significant portion of the energy gets through the plastic.
And if the sheet can be cut/melted with a laser, it can provide at least a partial protection against that particular wavelength.
That’s the reason why the CO2 folks can use about any acrylic glasses/goggles, and us diode operators need expensive glasses/goggles.
You do.
Both have the ability to severely damage Your eyes, even though the damage will be different and for different reasons with the different wavelengths.
In the end the reasons don’t matter much though, if the worst come to worst, You’ll be at least partially blind in a way that can’t be repaired with todays knowledge.
All the laser safety glasses with glass lenses I have seen have been in the price range that at least I can’t justify spending, so I’d say that the options are:
Cheaper (~<100€/$/£) questionable quality plastic ones that may or may not offer protection.
Moderately priced (~100~500€/$/£) plastic ones from reputable brands.
Expensive (>500€/$/£) professional plastic ones.
Like I said, I always use an enclosure and a camera, so there’s been no need to buy or to research deeper any expensive glasses or safety windows.
Regards,
Sam
