I`m looking for a way to make my scale factor the same, from the software to the machine.
100 mm on the software page is different once you sent it to the machine. any help would be appreciated.
Thanks Blanca
Thanks Blanca
It sounds like the machine isn’t calibrated properly - LightBurn sends commands like “move 10 mm left”, so the machine needs to know how big a single step is in order to do that correctly.
You can use Edit > Machine Settings in LightBurn to adjust the step length for each axis, and follow the instructions in the above post I liked for how to do this.
