Still haven’t gotten the galvo moving like I think it should, but can’t find anywhere to adjust or set limits for it’s speed.
Have sent a note via the Cloud Ray site asking for some assistance… I have no way to actually check the speed, but Lightburn is pretty close to the time at 300mm/s, but it doesn’t seem to go faster when I try 1500 or 2000mm/s. Even though lightburn shows only a half a minute, it takes 8. It has to be a setting, I’m thinking, as the image is correct…
When I installed Lightburn I used the EZCad2 markcfg7 file that came on the stick… as far as I know you can’t install EZCad2 on Linux… Edit: changed markcfg1 to markcfg7
What other files should I have? I have the stick copied to my ss drive…
Here is the device settings… I’m currently running. I understand this was populated by the EZCad2 file that I imported on creation of the device.
I changed the scale because the square came out with the wrong dimensions… that corrected that, but it makes me wonder about the rest of the setup… I also changed the min/max frequency to to 40 and 4,000 respectively…
From the JPT manual:
Full Power Frequency Range kHz 40-4000
Adjustable Frequency Range kHz 1-4000
But it’s really slow on the scan rate… At least it appears slow to me and to the times that the preview suggests. At 300mm/s it very close, go up to 1500mm/s, the preview time is 1/5, but it takes the same time to execute as the slower speeds… ?
I hope it’s a configuration issue as if one galvo was bad I’m sure I’d see it in the output…
It might be nice to figure out how to confirm it really isn’t working… suggestions?
EDIT: I think after running it and taking timings it seems to be working properly, so I will mark this solved. Not really sure I had a problem, but the times were different when I started this… I think/thought.
