Scanning offset adjustment seeming to not apply when bi-directional fill is off
I had some scanning offset adjustment issues and successfully dialed them in, however for some reason when I have the Bi-directional option unchecked the scanlines are aligned as expected, but the whole output is offset as though the offset adjustment was not applied
In the image above, you can see the top square is misaligned with the cut square at the bottom.
I tried fiddling with the “Initial offset” field but that had no affect on the outcome (I tried +1.2 and -1.2)
Am I doing something wrong here?
This is a bug that was introduced not long ago apparently. I’ve just fixed it for the next release.
Ah great, thanks for the quick update
