Hi,
using 0.9.24 on a Ubuntu 20.04 machine with a screen resolution of 1920x1080 I adjust screen settings and layout to suit my needs.
However, every time I restart Lightburn I find it reverts back to default display settings and I have to start all over again.
Checked the various settings and options.
Is there a way to save my settings so Lightburn always starts the same way ?
Thanks!
The only time we’ve seen it do this is if there isn’t enough room for the display layout chosen. Check to see if that’s a possibility here - giveaway is the tabs for the laser / Cuts&Layers / etc windows being scrunched up.
However, had to place an earlier post on here as I could never find the colour bar and then discovered it being hidden behind my taskbar - hence always have to re-arrange the layout to suit.
Resolution is 1920x1080
Also just checked to ensure it is standard resolution - not enlarged, as I know that can sometimes cause problems.
Follow up: After further testing and actual use with Laser I’ve made the following observation:
With above mentioned method the initial screen is fine. However, when loading a file the screen is refreshed and it reverts back to original settings. → Fix for this is to select “Special Application Settings” in above mentioned menu, rather than the Window Settings.
Unfortunately this results in all sub-windows displayed within Lightburn reverting to your custom screen size. I.e. opening the Machine Settings will be full size as well.
I still prefer this to not having all components of screen displayed as it was before.
