Unfortunately, there might be an issue with the S10 controller boards. I heard loads of reports of non-connecting board during the last days.
The S10 has NO standard grbl firmware, it uses an ESP32 controller and a port of grbl to that controller. Unfortunately, neither this firmware nor the source code is not officially available yet.
I have a slightly newer version of the firmware here, we might try to flash that?
@Melvin, are you seeing reports with this same type of error message? Curious if there’s a bug in the code that’s corruping the memory or perhaps there’s a batch of bad chips somewhere.
No, it’s the first time with these errors. Most users just can’t connect at all. At least that’s what I can tell right now. I just returned from short holidays and need to sort out all the reports. Maybe tonight I have more details.
So far, I found out that homing the laser also crashes the controller, but it reboots and is ready afterwards. But reproducible and the error message suggests some bad coding (access to non-existing memory area).
Yes, i already did that, so that means my board is fried
What did you do already? Your board doesn’t need to be fried, as long as you can connect / see messages, it is still working. Reflashing the firmware should be possible.
okay, so how do i do that? because i have tried what lies whithin my knowledge.
i already rebooted my pc several times, but if you could explain how i flash my grbl drive that would be nice.
Could you post a screenshot of the full console view after you connected to the laser? That would be interesting. The flashing process is not that difficult, the biggest hurdle is that the tutorial is partly in Chineese and you need google image translate to understand it
