What’s a power cycle? @killrob
Power cycle means turn off, wait 5 sec then turn on again the machine
Still doesn’t work…
I cleaned the laser yesterday, maybe I did something wrong about it?
I check all the wires and everything looks ok…
But your machine doesn’t Connect with LB at all? Can you try if works with LaserGRBL?
I use mac, can use GRBL…
I don’t know if LaserGRBL is avalaible also for Mac
I didn’t find it…
There are here a lot of user with your issue with sculpfun, take a look to see if someone has solved.
btw, take also a look on this video
and jump over the windows section, there is also the MAC section at 8:10
Your machine is quite a bit different from the xTool D1 thread that you responded to. You deserve your own thread where we can clarify what might be amiss.
Has the Sculpfun S9 ever connected? Is it new out of the box or was it working and recently stopped?
This may help get you going toward your solution:
