A photo is something different then a drawing.
This dragon is a drawing… only black and white.
The image is not just black and white… it has some grey shades in between.
To laser a black and white image is easy Just like any vector.
A photo is a different challenge…
try to burn the same image before and after registration and you will see that the result is exactly the same.
(too lazy to translate it to German, sorry for that)
@Patrick1997, post the settings for how you produced both, the good and the one that is not producing as you’d expect.
There is no difference in the trial from the paid version other than the time you have to play with it. What you are experiencing is something different in the way you had things set and going initially. Now we need to track down what changed. This is why the details you have been asked to provide are so important.
Which problem are we trying to address? You keep changing the image you are asking about. Please keep to one subject matter until resolved, then we can move to another. Otherwise, the context is lost and folks are providing answers that may not be correct and or send you off in the wrong direction.
You are posting an image of the preview window, which is simply showing the path that the laser will take - it is not an accurate rendering of what the final output will be. For example:
Sie veröffentlichen ein Bild des Vorschaufensters, in dem lediglich der Weg des Lasers angezeigt wird. Es handelt sich nicht um eine genaue Wiedergabe der endgültigen Ausgabe. Beispielsweise:
Please, Could you show the engraving data of channels C00 and C01? And, perhaps even “property ownership”
Könnten Sie die Gravierdaten der Kanäle C00 und C01 zeigen? Und vielleicht sogar “Eigentumseigentum”
This thread has gotten out of control. I have no idea what the current issue is that needs to be addressed. To illustrate, at one point I asked you for help and pointed out this concern:
We started with having the ‘Invert’ turned on in Preview, and I showed you how to resolve that issue.
Now, I see you post an image with error:5 issues, which is a ‘Homing cycle is not enabled via settings’ error from your firmware.
We are here to help, I just have no idea how to do that with what you provide in this post.
Upload the file here I will look at it.
But just to be clear, there is nothing in LightBurn that is different in the trial version compared to the paid version, this is not an unqualified guess but a fact.
