Magier7
(Stefan Bodingbauer)
August 17, 2021, 11:56am
1
Hi
i have a problem with setting the scan offset i tried to proceed according to the instructions
https://lightburnsoftware.github.io/NewDocs/ScanningOffsetAdjustment.html
however, it’s somehow completely different with me
with device settings
and also with the cut settings
now I don’t know how to adjust that
can someone help me with this?
jkwilborn
(Jack Wilborn)
August 17, 2021, 6:02pm
2
I believe your Ruida controller will handle this automatically
Good luck
Magier7
August 17, 2021, 8:06pm
3
why is my engraving moved?
how can I set it to do this?
jkwilborn
(Jack Wilborn)
August 17, 2021, 8:09pm
4
It would help if you could show us what you mean.
Screenshot or ? Upload the .lbrn2 file by dropping on this window.
Magier7
August 17, 2021, 8:21pm
5
should look something like this
Laurenz.lbrn (456.1 KB)
and actually you should be able to engrave it faster
jkwilborn
(Jack Wilborn)
August 17, 2021, 8:40pm
6
Looks like it’s been run twice…?
Magier7
August 17, 2021, 8:43pm
7
that was engraved and cut out in an engraving
no second round
what can I do to prevent this from happening?
jkwilborn
(Jack Wilborn)
August 17, 2021, 9:11pm
8
This area
This is from the preview.
The head would have to make a 2nd pass to double these lines like this. Is that what’s happening?
You should not be running your tube at 100%, you will have a short time together.
Magier7
August 17, 2021, 9:19pm
9
jkwilborn:
it was definitely only one passage
thanks for the tip with the 100%
what can I do to prevent that?
jkwilborn
(Jack Wilborn)
August 17, 2021, 9:25pm
10
Don’t know how big this is, but if it’s making two lines with one pass you have an issue.
Tried a ramp test ?
What kind of results do you get from the ramp test?
Have you checked the beam alignment ?
Magier7
August 17, 2021, 9:28pm
11
beam alignment is ok
Ramp test?
do you mean the focus?
jkwilborn
(Jack Wilborn)
August 17, 2021, 9:30pm
12
Magier7:
How do you know?
I find it difficult to believe it makes one pass and burns two lines. And you beam is aligned?
That’s a link to the ramp test…
Hank
(Hank Morgan)
August 17, 2021, 9:36pm
13
Magier7:
If that’s the result you get from 1 pass on that file then your beam alignment is NOT OK.
Is the beam clipping the inner edge of the nozzle? That’s a common reason for the beam to be split and make 2 marks like that.
Magier7
August 17, 2021, 9:38pm
14
I’m sorry but I saw it that way! unfortunately no link
Magier7
August 17, 2021, 9:43pm
15
then the jet would also come to the nozzle when I cut and also double the cut but that is not the case that is only when engraving
jkwilborn
(Jack Wilborn)
August 17, 2021, 9:45pm
17
I understand, but it is either making two pases or making two lines in one pass.
Do the ramp test and post a photo… We are trying to help…
Magier7
August 17, 2021, 9:52pm
19
that may be
So my tip is that the laser switches in one direction and the laser switches in the other direction later, so the offset switches the question about the scan offset
how can I prevent it?
jkwilborn
(Jack Wilborn)
August 18, 2021, 1:59am
20
you lost me here… You have the layer set for bi directional fill.
You’d visually see the laser track here if it were going over that area. You can also see it in the ‘preview’ with ‘show traversal moves’ enabled.
You keep telling me beam alignment is ok, but everything else says it’s not.
Can you post a photo of the ramp along with just the dot on paper on the table. I’d like to see what kind of a beam you have at the table. Both with lens and without. Just a pulse…
