Seting up chuck rotary
Hello
I install steper motor driver for chuck rotary and set it up do work with Rudia driver.
Engine works smooth and everything is OK.
Now I try set up chuck in rotary settings.
I enable rotary set circle pulse to steper motor settings 10000
Test it and chucks rotate 3 times + 10-15deg
I start tune up it bot there is no difference 200-36000 pulse results in 3 rotations +10-15deg
The proper way to set these up is outlined here.
You have to ensure you enable the rotary and use the test button to check it. It should rotate a chuck one complete turn and back… a roller rotary should rotate the drive wheel one rotation and back.
