My machine is currently homing (on startup or reset) to the bottom left. This is with RDWorks ‘Dir polarity’ set to “Negative” for both axes. I want to home to top left. If I change ‘Dir polarity’ to “Positive” on the Y axes, the machine homes to top left as expected, but then the keypad does not allow me to move the laser-head to the right, presumably because the direction has now been swapped. So, that makes me think that the original ‘Dir polarity’ was correct. I cannot find any other setting which allow me to tell the controller in which direction to seek the limit switch on startup. Does anyone have any advice?
Thank you. Good news is that I managed to solve it (using LightBurn) by inverting the ‘direction polarity’ and then also inverting the keypad direction on the Y axis. In RDWorks I could not find a toggle for keypad direction. And it seems that the setting for “inverting keypad direction” is more than just inverting the keypad direction, because the machine operates at it should when controlled directly from lightburn as well. So it seems that the “keypad direction” setting is more of a global direction setting.
