jkwilborn
(Jack Wilborn)
January 17, 2024, 2:13am
15
See if this may help…
It’s a new setting for images that is used to compensate for the fact that your beam has width.
If you tell LightBurn to dither an image. On a 50% grey bit, it produces alternating on/off short line segments, like this:
[image]
If you draw the width of the beam, it looks more like this:
[image]
If you look at that 2nd image, the gaps between the lines are shorter now than the lines themselves, because of the shape of the beam. ‘Dot Correction’ is the total amount to shorten the line, t…
There is a more extensive explanation done by Laser Everything in their photo engraving video . The description is by the Lightburn developer.
Most of these diodes are rectangular. I also don’t know which way they are orientated. Most of these are also slightly exaggerated compared to real life.
Good luck
