We have a Mira 7 laser and are using Lightburn for the software.
We are having a problem with shapes inside of shapes sending to the Mira.
When we send numbers 1,2,3,4,5,7 they will cut right. When we send numbers 6,8,9.0 and they won’t show up on the file.
Sometimes it is just circles inside circles or shapes inside of shapes.
For an example we made these numbers on Lightburn 4 and 6 and had to take the center out of the 4 and 6 to make it cut.
We saved it multiple was and nothing would work.
It is probably something really simple that we aren’t doing but really could use your help.
Thanks!
Great, that is exactly why we offer this forum!
We are going to need a bit more detail, though. It is difficult to envision what you describe. Let’s start with what you are trying to produce, show us. Please post screenshots, pictures of the results you get, the LightBurn file itself, and an example of what you are trying to produce, and we can go from there. ![]()
Here is a guide for what we are after to best assist you.
Thank you,
The first photo shows that we are sending numbers 46 to the Mira 7 directly from Lightburn. It gives us an error and won’t print the middles. The second photo shows what we have to send to the Mira 7 to get it to print. The third printer shows another project we are trying to cut that has shapes in the middle. It will cut fine without the middle shapes but won’t cut with the middle shapes.
Can you upload your LBRN file?
