Sizing randomly decided to go 10X, meaning 1mm = 1cm
I’m working on a mac running venturi on a chinese diode (LDHTHOPI) and it randomly started increasing sizes 10x. Says mm, produces in cm. Which was particularly disturbing when it started running to it’s maxes and screaming at me during framing. Here are settings
$0=10
$1=25
$2=0
$3=6
$4=0
$5=0
$6=0
$10=1
$11=0.010
$12=0.002
$13=0
$20=0
$21=1
$22=1
$23=7
$24=25.000
$25=500.000
$26=250
$27=2.000
$30=1000
$31=1
$32=1
$38=10
$100=800.000
$101=800.000
$102=800.000
$110=2000.000
$111=2000.000
$112=100.000
$120=20.000
$121=20.000
$122=20.000
$130=500.000
$131=500.000
$132=200.000
ok
Did you change these values? I suspect these are meant to be 80 in both cases.
@werdh2ofall has the same question that they added to a similar thread… Can you combine them?
Berainlb, I did not change the values, but I did change them “back” and it solved the problem. Thank you so very much. I’m not sure how things get changed in my world they just do.
This seems like a similar problem to what I am running into currently. Mine suddenly decided to 10X all of the sizes. Meaning that if I cut a square 1mm it actually frames and cuts 1cm, which obviously not Ideal and I would like to figure out how to fix it; other than moving decimal points.
