Slanted/Skewed when Engraving
Also, it seems as if this is only when using “fill”.
What settings were you using? Are you connected via USB?
I’ve tried both ethernet as well as USB. Fill at 150 mm/s and 20% power. Line at 15 mm/s and 35% power.
Both ethernet and usb skew in the same spot.
Try this to see if it helps:
That seems to have helped. I need to try some more cuts and see if that solved the entire issue.
