Smartcarve ratio parameters in Lightburn
We are using Smartcarve software and wanted to try the Lightburn software.
I can’t find any parameters of the old software.
the parameters are:
Cutting parameters:
  • cut ratio
  • space ratio
  • corner ratio
    Can you tell me where I can find these parameters?
I have no idea what they mean… you need to find someone who can tell you what those do or how they relate to cutting/engraving…
There isn’t anything that I’ve seen in Lightburn that’s similar.
The only difference between engraving a line and cutting a line is power/speed…
If you can use it for the laser, there’s probably something similar in Lightburn… Never heard anything expressed as ratios that I can recall…
Maybe if you tell us what you are trying to do, we can make some suggestions.
Good luck
From what I can tell after a quick review of the Smartcarve parameters LightBurn may have a different process from what Smartcarve uses.
If you’re willing, please share parts of the instruction manual so I can get a clearer understanding of what you’re attempting to replicate.
This may help you arrive at better answers:
