Snapmaker 2.0 1.17.17 Firmware Works Better
It seems they finally got around to fixing the firmware on the 2.0 machines. From the little testing I’ve done, it seems following my full lightburn control guide no longer requires custom firmware. They’ve enabled inline, and fixed the dangerous bug so now it acts like similar to what you’d expect from a GRBL machine.
If you haven’t followed by guide, it was to control the Snapmaker 2.0 from Lightburn, but also to increase accuracy, speed, and enabling inline power control (vs the stock stop and go stuttering making even small engraves take ages). Now it seems everyone can enjoy fast, accurate, repeatable, automation without flashing custom firmware. :slight_smile:
Not Yet, I have a BUG while using V1.17.17 with the 10W Lasermodul.
I´m not able to work with the Maschine because i´m stuck in the safty guide.
Update at V1.18 was better, but i still have the problem, if I let the rotary module rotate, the Y axis also moves the value which stands in diameter
