used both change module AND manual power off/switch
Placed metal coin in jig hole
Frame is off by what feels like is exactly the laser offset established in the 2w laser lightburn settings (x21.5, y -11). It is slightly “down and to the right”
Item does not correct/shift position at all when I switch off the offset function or initiate burn
What ive done:
Reattached 40w, frames and cuts exactly where intended to ensure I did not move jig or mis calculate frame
Shut off enable offset, rebooted lightburn - no change
Changed offset to wildly different numbers, no change
verified “40w” laser offset is not carrying over when I switch device profiles
Snapmaker Ray user here. I had this issue a while back but moved on from the problem without solving it.
I just did a quick ai search and it suggested the X-Y calibration must be adjusted after turning off snapmaker - Turn On - select device and Module - adjust X-Y coordinate manually.
This can also be done by changing G-code…not my speciality! But looks simple enough.
I think it means…to get the 40w dot and the 2w dot both starting from same place.
I’m short on time here so can’t get into it right now, but can do later…sorry I haven’t done this before now.
If you figure it out remember to save the new coordinates to that device so you don’t have to recalibrate every time.
So interestingly, I created a cross hair on sacrificial piece, and the math to see if I needed to make my own offset…it came out as x21.5,y-11! So what I did, was I reversed it and got closer. looks like it was closer on the y axis, but it was off center for the coins X axis. Very odd since all I did was reverse the positive and negative of the offset (-21.5x,11y). So this is VERY odd. I want to say snapmaker needs to identify the real offset here. I need to get this post over to snapmaker.
Not much time for researching so far but there seems to be no reference documentation regarding physical X=0/Y=0. So, my imagination kicked in and suggested to find a ‘Start From’ point located at physical dead centre on the cutting deck and Test/calculate outward from there to the outermost distance where both dots corelate and that’s the outer boundary for the jig.
The 2wIR is 0.03x0.03 and my 20w is 0.1x0.8 so calculate the dead centre of the 2wIR dot within the dead centre of the 20w dot and manually test - Adjust and save coordinate.
Not sure if that’s the easiest way of doing it but maybe it’s on the right path.
