Snapmaker Artisan with Rotary for laser
I would like to use my rotary in lightburn with my snapmaker artisan laser can you please update your software to make this work or does anyone know a work around for this
Much Appreciated
Lightburn already supports rotaries. If the Artisan does not support a rotary, Lightburn cannot fix that.
Tell us what your problem is and maybe we can help.
An update to Lightburn to add the B axis to the grbl-M3 101 or earlier? I would like to be able to use Lightburn for engraving Tumblers, but without the B axis, my rotary will not work since Snapmaker updated the Firmware and does not use Marlin any longer.
Don’t work for lightburn, but unlikely because the other versions of GRBL are considered obsolete. I believe you should be using just thr GRBL device type.
A quick search provided what appears to be relevant info…
