Hi - I’m new here and had found a thread before joining that I had wanted to comment on - but upon joining I can no longer find it.
I’m trying to connect my 350 to LightBurn - I’ve gone through and added my machine manually, picked the correct Com port, ensured that the correct driver is installed (CH340), turned off the door detection on my console for the enclosure and changed that baud rate to 115,200. LightBurn software is showing that the laser is “ready” but I have no “move” tab. I’ve tried to get it to frame, go to origin and home - all with nothing happening on the machine.
Try right-clicking the Devices button in Laser window. If you see the “Ok” in Console, can you type $I in the entry field and hit enter after that? What does Console show then?
I have no idea what I did - but now it seems to be connected to my Snapmaker. But for some reason when I tell it to go to the origin - the laser is not even on the bed. I have the bed size set at 320 x 350 y but this is how the laser is sitting.
I believe I can can get full use of the bed - I haven’t tried yet. Just trying to get everything sorted out here before throwing a full bed project at it.
After I get this sorted out - I have to figure out how to focus the laser.
Yes that was the position it was showing after homing. I shut the machine off last night, and then came back to it this morning and it is showing the same coordinates. 0, 347 puts me on the bed, but even though the machine coordinates appear to be set correctly (320x- it won’t use the last 35mm at the top of the bed.
