Snapmaker Ray positioning issues after new PC
I recently had my laptop die on me so I’m now using another PC. When I setup Lightburn and and use the move controls the positioning isn’t registering or something, not really sure. I have Home at X=0 Y=400. If I jog it to any direction it will register that distance one time then any additional jogs will not. If I jog the other direction the same thing happens except it resets the other axis. It appears to be reseting the position to X=0 Y=400 on every move. Nothing I have tried works. I’ve tried reloading the machine lbdev and reflashing the firmware.
Any help would be appreciated.
Edit 7/18/2024
This is printing in the console and should not be. I don’t know how to keep it from resetting sys position and offset coodinates.
Starting stream
[I][PLAT]Program End
Stream completed in 0:01
[I][PLAT]reset sys pos and WCO because disabling motor
[I][PLAT]reset coordoffset
[I][PLAT]max rpm: 0
[I][PLAT]max rpm: 1000
<Idle|WPos:0.000,400.000,0.000,0.000|FS:0,0|WCO:0.000,-400.000,0.000,0.000|SD:8.44,boundary.nc>
[I][PLAT]Set coordoffset: 0.000, 400.000
Do this to make the results come out the same:
I appreciate the response but in my case I didn’t have the opportunity to export anything. I was only smart enough to use NAS for backing up my project files which did backup laser setting for each project but that’s all I had. Anything on the local drive where Lightburn autosaves is toast.
I setup Lightburn before just fine and without any issues once I had the Y -400 set but things didn’t go as smoothly this time which this new issue I hadn’t encountered or found anyone else discuss before.
Check the .lbdev files here:
https://wiki.snapmaker.com/en/general/manual/use_ray_with_lightburn_guide
Thanks for your response. Yes, those are the ones I used when reloading all my files. I’ve deleted all my devices and reloaded them with a new download of this file. I also reflashed the Snapmaker Ray firmware just to be sure. It does appear to be a disconnect between the machine and the Lightburn software. I used Snapmaker’s software Luban just to see if it worked properly and it does so that isolated Lightburn software and the machine being the issue.
Anyone know why it would be resetting the sys position and offset coordinates?
Starting stream
[I][PLAT]max rpm: 0
Machine Info:
Starting stream
$Sta/SSID=GTAX11000
$Sta/Password=******
$Sta/IPMode=DHCP
$Sta/IP=0.0.0.0
$Sta/Gateway=0.0.0.0
$Sta/Netmask=0.0.0.0
$AP/SSID=RAY2023
$AP/Password=******
$AP/IP=192.168.0.1
$AP/Channel=1
$System/Hostname=ray
$Http/Enable=ON
$Http/Port=80
$Telnet/Enable=ON
$Telnet/Port=23
$Radio/Mode=STA
$Message/Enable=Off
$Message/Level=Info
$User/Macro0=
$User/Macro1=
$User/Macro2=
$User/Macro3=
$Homing/Cycle0=Z
$Homing/Cycle1=XY
$Homing/Cycle2=
$Homing/Cycle3=
$Homing/Cycle4=
$Homing/Cycle5=
$Report/StallGuard=
$Stepper/Enable/Delay=50000
$Stepper/Direction/Delay=0
$Stepper/Pulse=1
$Stepper/IdleTime=100
$Stepper/StepInvert=
$Stepper/DirInvert=Y
$Stepper/EnableInvert=Off
$Limits/Invert=Off
$Probe/Invert=Off
$Report/Status=0
$GCode/JunctionDeviation=0.006
$GCode/ArcTolerance=0.002
$Report/Inches=Off
$Firmware/Build=
$Limits/Soft=Off
$Limits/Hard=On
$Homing/Enable=On
$Homing/DirInvert=X
$Homing/Squared=
$Homing/Feed=300.000
$Homing/Seek=3000.000
$Homing/Debounce=250.000
$Homing/Pulloff=2.000
$GCode/MaxS=1000.000
$GCode/MinS=0.000
$Laser/FullPower=1000
$GCode/LaserMode=On
$GCode/Line1=
$GCode/Line0=
$Spindle/Enable/Invert=Off
$Spindle/Enable/OffWithSpeed=Off
$Coolant/Delay/TurnOn=1.000
$Spindle/Delay/SpinDown=0.000
$Spindle/Delay/SpinUp=0.000
$Spindle/PWM/Invert=On
$Spindle/PWM/Frequency=5000.000
$Spindle/PWM/Off=0.000
$Spindle/PWM/Min=0.000
$Spindle/PWM/Max=100.000
$Spindle/Type=LASER
$X/StepsPerMm=80.000
$Y/StepsPerMm=80.000
$Z/StepsPerMm=100.000
$A/StepsPerMm=888.889
$B/StepsPerMm=100.000
$C/StepsPerMm=100.000
$X/MaxRate=30000.000
$Y/MaxRate=12000.000
$Z/MaxRate=1000.000
$A/MaxRate=1500.000
$B/MaxRate=1000.000
$C/MaxRate=1000.000
$X/Acceleration=2000.000
$Y/Acceleration=200.000
$Z/Acceleration=200.000
$A/Acceleration=500.000
$B/Acceleration=200.000
$C/Acceleration=200.000
$X/Home/Mpos=-1.000
$Y/Home/Mpos=401.000
$Z/Home/Mpos=0.000
$A/Home/Mpos=0.000
$B/Home/Mpos=0.000
$C/Home/Mpos=0.000
$X/MaxTravel=600.000
$Y/MaxTravel=400.000
$Z/MaxTravel=300.000
$A/MaxTravel=3600.000
$B/MaxTravel=300.000
$C/MaxTravel=300.000
$X/Current/Run=1.100
$Y/Current/Run=1.100
$Z/Current/Run=0.800
$A/Current/Run=1.100
$B/Current/Run=0.800
$C/Current/Run=0.800
$X/Current/Hold=0.800
$Y/Current/Hold=0.800
$Z/Current/Hold=0.400
$A/Current/Hold=0.400
$B/Current/Hold=0.400
$C/Current/Hold=0.400
$X/Microsteps=16
$Y/Microsteps=16
$Z/Microsteps=16
$A/Microsteps=16
$B/Microsteps=16
$C/Microsteps=16
$X/StallGuard=16
$Y/StallGuard=16
$Z/StallGuard=16
$A/StallGuard=16
$B/StallGuard=16
$C/StallGuard=16
$Errors/Verbose=Off
[VER:V1.7.4.20240702:]
[OPT:PHSW]
[I][PLAT]Machine: Snapmaker Ray Controller
