Software download for Ruida controller
I have just “inherited” a CO2 laser. it is a Sinmic SL1390 with a controller board labelled RDC6442S(EC). I have upgraded to Lightburn Pro (Already have diode lasers which I am very familiar with) to use the RuiDa drivers, but although my Windows10 PC sees the laser through the USB cable, it won’t communicate with it. I have downloaded and installed RD Works as well as other Ruida drivers but they don’t seem to work. I understand Lightburn has an available driver that is compatible; can I download it please?
Just Re-Run the LightBurn installer, and on the last page check the box to install the FTDI driver. That is the driver that’s needed to communicate with a Ruida controller over USB.
Likely the CH340 driver.
If you’re feeling lucky today:
You can, however, avoid an unlimited amount of USB heartache & confusion by using the controller’s Ethernet interface:
A direct Ethernet connection between the PC and the laser will get you running right away.
Might take a look here, from Laser Everything.. EASY! Swap Between LightBurn and Ezcad FAST
You can see the driver reported to Windows, but it may not be the right driver for Lightburn.
:grinning_cat:
FYI my Ruida is far more stable using ethernet than USB. Had to get some help configuring it.
Within a couple of weeks with a new laser, I bailed out of using USB and went to Ethernet. What a relief. I bought a low cost router/bridge from Amazon it works fine with my co2 out in the garage. Lightburn makes a similar bridge that I have used, but the PI just doesn’t appear to be as tough as my my Chinese built T-link bridge, when thunderstorms are involved.
I agree with anyone who suggests the same, if that’s any consulatioin?
:grinning_cat:
Hi people, thanks for all your help and suggestions. I’ll have another go, but I’ll try ethernet this time. it should be able to handle the extra load that a CO2 laser will put on it. Will keep you posted…
Data is not the problem.
The fragility of a USB electrical connection is the problem and it is a real problem. :frowning:
Hi. I finally got back in my shed, and changed from USB to Ethernet. Thanks for all your comments, I now have everything up and going. it’s so efficient, I probably won’t be going back to my diode laser anytime soon.
So glad to have this forum …
