Has anyone had the issue when they increase the power and the engraving gets really bad, I went from 12% power 65 Speed in image on where the image is normal to 13% power speed 65 for image 2 and it just gets worse. Went back down to 12% for image 3 to make sure i wasnt going crazy
I have also tried PWM Raising Edge and this didnt work just makes things worse
Machine: 4060 50w Chinese Laser with Ruida Controller
It’s exactly same image same speed same login the machine, I move the wood each time. Air assist yea with just changing power from 12% to 13%(or above)
I’m failing to see the problem - you keep the speed the same but increase the power and the quality drops? That’s what I would expect to see, as more power means more ablation at a higher temperature, with associated smoke adherence and heat discolouration.
You’re raising the light pressure without any other compensation.
If you raise the power to 65%, while keeping the speed the same, does it cleanly etch a mm or so?
And what are you trying to achieve with the change in power? Your initial engraving looks fine.
Can you see the image? It’s not the same image it’s all squashed up and it’s like missing steps when I go above 12% so it’s not like I’m running a lot of power
