I’m trying to change from Topwisdom to Ruida, RDC6445S(EC)
I’ve added a ruida manual connection to devices, showing laser disconnected.
Here’s my IP config, ruida IP settings, and showing i’m still unable to ping it.
For some reason it’s still showing nothing plugged into my ethernet port?
Yes the controller is powered on ha! Is there something i’m missing network wise here?
I could also just go via USB, but for some reason lightburn wasn’t auto detecting anything when I was trying to search for devices that way. So had to set up a device manually and follow the lightburn guide to setting up an Ethernet connection.
I changed the I.P addresses but still couldn’t understand why it showed no connection in the ethernet port. Found it wasn’t fully pushed in hahaha! What a sausage I am.
Using your recommended settings though so there’s no port clash, I would have still had that issue so thanks.
