Support Monport GA 60 with Cypress FX2LP ( BslCAD )
Hello,
can someone please tell me if Cypress FX2LP and BslCAD (Monport) is supported by Ligtburn?
Thank you very much
Sven
Hello Sven,
Assuming your Monport provides the bslconfig file and you are running 1.7.0 or greater it should support it.
Have you ran the Free Trial to confirm?
Hello Gil,
I have the full version 1.7.03 ( Galvo).
I get the monport installed and can also laser to some extent, but framing does not work, for example.
It works in BslCAD.
Thank you very much
Sven
@gilaraujo
Do you have any idea what / where else I can look?
Thanks for your help
Sven
Hi Sven
Did you import the BSL config file? Do you have it so you can send to support@lightburnsoftware.com?
Yes and I have sent the file by e-mail.
Thanks
Sven
I am very new to Fiber lasers. I just received my Monport GA 100. It had a BSL board in it and not the JCT. I updated my driver and configured manually. My tracing works.
I did have an issue once when I forgot to remove the lens cover. No tracing then. Ha Ha.
Not sure if I really know enough to help but will help what little I know.
The problem was the setting: Red Dot = None. I changed None to 0 and then it worked.
I found the error with the help of the support team, thank you very much.
I have a Monport GA100 that has a two pin port that is labeled door switch. The voltage a cross it is at logic level. When I short the pins through my ma meter, it pull 8 ma. But I don’t see a status change in Lightburn. See my attached config screen capture above where all status is red. None turns green. Any thoughts?
Which screws can I remove to take a look inside?
