My SVG file was edited in Inkscape. One path was partially clipped/erased - it does not appear in Inkscape, but when I import the SVG file to LB, the path I erased is back.
Is there a setting I am missing? Would it be easier to just “erase” those lines from the LB file?
Most likely the path was not actually altered, but just set as a mask, which isn’t supported in LightBurn yet. It would be similar to drawing a shape, then painting over it with a white shape to make it disappear - LightBurn will retain the outlines of both, so you need to actually alter the shape to what you want for the final result.
