Text and Fill Issues
So if I want to make a square and set to fill then I add text inside the box, how can I get it to only fill the box incorporating the text. Hope this makes sense
so one way to do it is give your text a slight outward offset. with the offset line set as the same color layer as the box.
You mean exclude the text from the fill? Just make the text the same color as the box. It happens automatically.
LightBurn uses the boundaries of shapes to turn the filling on and off. This post will help you better understand this concept.
